Reaction using Flory Washes
    November 2008
Posted by plasticjunkie on Monday, October 12, 2015 12:26 PM
I recently used Flory Washes over MM Flats, decals on with Solvaset and  sealed in Future and it worked like a charm.
A couple of evenings back, I applied the same wash to a plane painted with Testor's Gloss white, sealed in Future and decaled with Set and Sol with no Future applied to seal over the decals. The wash separated as if it was bad. I really had to work to get it into the panel lines. A little Dawn helped out.
Then I took the same wash with the same brush and applied it to an old unpainted Fujimi plane wing, it worked just fine.
Again, the brush was brand new and had not been used with anything else so no contamination from the brush. Even using Q tips got the same results.
Has anyone experienced this weird effect while using Flory Washes? A reaction to Set and Sol? Reaction to the paint brand?
 GIFMaker.org_jy_Ayj_O
Posted by Texgunner on Monday, October 12, 2015 1:37 PM
Ernie, I believe I would contact Philip Flory and tell him about your experience.  He might be able to explain what happened. That is sort of strange...
Gary
"All you mugs need to get busy building, and post pics!"
    November 2008
Posted by plasticjunkie on Monday, October 12, 2015 1:53 PM
Gary
sounds like a good idea. Just wondering if anyone else had a similar experience.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, October 12, 2015 5:07 PM
I'm thinking it dont react as well on gloss paint as it does on flat paint.
I've been trying to find Flory washes and pigments here in the US but having no luck. Where did you find it?
    November 2008
Posted by plasticjunkie on Monday, October 12, 2015 5:32 PM
You have to order from them in the UK.
    November 2008
Posted by plasticjunkie on Tuesday, October 13, 2015 9:09 PM
The mystery continues......I just ran the same wash over  Floquil Old Silver sealed in Alclad Aquagloss and the wash worked like it should.
Posted by Bish on Wednesday, October 14, 2015 1:04 AM
I have had similar issues as PJ over the few years i have been useing it. It does not seem to like Xtracolour paint of Alclad lacquer clears, but goes down fine on future. BUt it can be hit and miss.
As PJ said, you now have to order direc from Flory. But postage is a flat £3.50 what ever the order size.
http://www.florymodels.co.uk/
