Cutting resin parts
    April 2023
Cutting resin parts
Posted by KeithRob on Sunday, June 4, 2023 8:49 PM
I ordered some 1/48 scale resin stowage kits and being new at this I was curious what is the best way to cut the parts from the mold?  I have an X-acto saw that I've been using but is there a better way?   Such as a Dremel?   I didn't expect the resin to be so hard.  I had never worked with it before.    thanks
"Charlie don't surf!"
Lieutenant Colonel William "Bill" Kilgore
    September 2006
Posted by the Baron on Sunday, June 4, 2023 9:27 PM
I use a fine-toothed razor saw to remove resin parts from their casting blocks, but not one of my X-Acto saws. The kerf on those saws, even on the fine ones, is too wide for my taste, for this kind of job.
I use this saw from CMK, though there are other makers who make the same kind of blade and similar handles:
Some of these saw blades are actually made in a photo-etching process, and are very thin.
I will also use a Nr 11 blade to score along the cutting seam, to remove parts from the casting blocks, too.  It depends.  I've used a sewing needle to score along the seam to remove it.
Hope that helps!
    April 2023
Posted by KeithRob on Sunday, June 4, 2023 9:29 PM
thank you
Posted by Rob Gronovius on Sunday, June 4, 2023 9:44 PM
The dust is hazardous and you don't want to breathe it in. Most of us use the saw blade in the X-Acto knife handle to minimize the dust created.
    April 2023
Posted by KeithRob on Sunday, June 4, 2023 9:46 PM
yeah I have read that.  I wear a mask while I saw.    thanks
    April 2020
Posted by Eaglecash867 on Monday, June 5, 2023 6:13 AM
I use a jewelers saw with a fine spiral blade on it.  The blade has an extremely small cross-section, so you're not limited to just making straight cuts.  You can follow the countour of the piece you're removing the base from.  It also keeps the dust level lower than anything else I have used.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    August 2005
Posted by EdGrune on Monday, June 5, 2023 6:42 AM
the Baron
Those CMK saws are good for lighter duty work but clog rapidly when used on heavier resin plugs.
Don't use the cutting edge on your #11 blade. It seems to work faster by turning the blade over use the backside of the point to drag material out of the separation line.
Refrain from using a cut off wheel in a dremel.  It throws dust everywhere and allows you to screw up faster than doing it by hand
    April 2023
Posted by KeithRob on Monday, June 5, 2023 7:51 AM
thanks
    September 2006
Posted by the Baron on Monday, June 5, 2023 12:24 PM
EdGrune
Those CMK saws are good for lighter duty work but clog rapidly when used on heavier resin plugs...
I use them on plugs from things like cockpit details for 1/48 scale aircraft, 1/35 scale figures, and larger anime figures in 1/8 and 1/6 scale, where the casting blocks can be quite thick.  I haven't had any problems with those cutting jobs.  Of course, everyone's mileage may vary.
    September 2012
Posted by GMorrison on Monday, June 5, 2023 5:19 PM
My last step is sanding to the finish dimension rather than cutting to it in the beginning.
Bill
    May 2009
Posted by Pawel on Monday, June 5, 2023 6:46 PM
Hello!
For small to medium pour blocks I recommend a knife like this:
Plastic cutter
Many companies including OLFA sell them as "plastic cutters" - they cut a V-groove in plastic, and if you use them on resin you get long shavings or curls instead of dust.
That's what I use - have a nice day!
Paweł
www.vietnam.net.pl
    March 2022
Posted by missileman2000 on Tuesday, June 6, 2023 9:45 AM
Razor saws generate a lot of heat while cutting any kind of plastic, and  tiny amounts plastic actually melt!  I keep a small dish of water on the bench while sawing.  Eliminates the sticking and allows you to saw faster.  Same as oil when cutting metal.
    October 2019
Posted by Tanker-Builder on Thursday, June 8, 2023 6:09 PM
Hey!
    Promise not to laugh?  Remember I said i was allergry Sensitive to Resin? Found a way around some of it. Photo Etched saws! And Water and a large Pyrex Baking Dish(Casserole size)! Now I am building some long wanted model cars that are resin.
 These P.E. saws are very thin as expected. And using them underwater has, if anything, wether plastic or resin, made them eaiser to use and so there you go! And of course being very thin saws, some no thicker that the (I )on your keyboard there is virtually no Binding!
    December 2022
Posted by CFster on Friday, June 9, 2023 10:10 PM
 ZONA - ZON35-550 35-550 Fine Razor Saw, 42 TPI.010-Inch Kerf, Blade Length 6-1/2-Inch,
