Some questions about clear final finishes
Posted by Anonymous on Saturday, February 22, 2003 10:25 PM
I have heard most modelers say that Testor's dullcoat finish should be applied in THIN coats - allowing drying time between coats, of course.
But there are also a few modelers that have stated if the first coat is TOO THIN you might get a "spotty" finish on your model (this happened to me once on a semi gloss paint job). They were usually referring to the spray can of dullcoat. I know that you should shake or mix the dullcoat well to avoid getting that "frosty" finish - but this wasn't what they were talking about.
Also, do you think that the clear acrylic gloss finishes that are milky colored, like Model Master, might end up turning the finished model yellow over time? What about that?
Posted by weebles on Sunday, February 23, 2003 12:11 PM
Normie1, don't use Testors flat finish. It models on the finish. It will leave your model looking like it needs a dermatologist. My recoommendation is to use Microscale flat finishes. I've never had a problem with it. I've also used Floquil with great success. I'm saying this hoping that you have an airbrush.
If not.... I'm not sure what your best option is. Perhaps somebody could help here.
That said, somebody put out a post that I want to try. They used Tamiya flat base mixed less than 50/50 with Future. I think I would start with something like 25% at first and experiment from there. Future can go on by airbrush, brush, or dipping. I'm not sure how this mixture will behave, but I want to give it a try sometime soon.
As far as clear acrylic gloss goes there is only one choice and that is Future Floor Wax. It will never yellow. Great stuff and easy to use.
Hope that helps.
Good luck/Dave
Posted by Anonymous on Sunday, February 23, 2003 6:04 PM
Yes Dave, I've got the airbrush. I just never used it for applying a clear finish. I've heard some say that it can be a little tricky applying it with an airbrush so I used the aerosol can instead. One thing I know is that an airbrush will lay on a much more even coat than the aerosol. It's probably the best way to do it.
Thanks,
Norm.
Posted by weebles on Sunday, February 23, 2003 11:10 PM
Yea, since you have the airbrush I would recommend going that route. I remember years ago when I used the Testors clear flat sometimes it would work, and most of the time it didn't. Once I switched to the Microscale product my problems went away. The Future suggestion is interesting and I can't wait to give it a shot. Forgive the punn.
Dave
Posted by Anonymous on Monday, February 24, 2003 9:02 AM
Try using Minwax Polycoat. With a soft brush it goes on easy, drys fast and wont yellow. You can get it anywhere.
Posted by jcarlberg on Tuesday, February 25, 2003 3:51 PM
I often use Microscale flat coat on smaller scale models with just a hand brush. It levels well and doesn't leave streaks or spots. I think the problem with the Dullcote lacquer spray is that it gathers around the nozzle then spatters on the model, but it also can attack the underlying paint and leave a real mess. I've found that it helps if the model surface is warm but not hot, the can has been warmed in warm water, and the nozzle has been soaked in lacquer thinner. But mysterious and unpleasant things still happen!
