Paint booth water filter
Posted by Anonymous on Thursday, February 27, 2003 10:23 PM
Greetings
I am building a paint booth and am not able to route the exhaust outside. I have read of a "water filter" system being built of a 5 gallon bucket, rocks(?) and water.......
Does anyone have any insite on this?????
Any assistance is appreciated.
Posted by Anonymous on Friday, February 28, 2003 2:17 PM
never heard of that, and I dont think it would work because particles would still get out through the water via the air bubbles coming up...your best bet is if you are in a confined space, try and make a filtration system from air filters and a fan to force it through there...or even try a air filter (like the one from Sharper Image). May be the best bet....good lluck
Posted by Anonymous on Friday, February 28, 2003 3:12 PM
There was a side column in a recent issue of FSM about this type of filter. I'll have to go back and see if I can find it. Anyone else know which issue it was?
M.
Posted by Anonymous on Saturday, March 15, 2003 10:26 PM
seems like it had carbon as a filtering agent as well
David
Posted by SNOOPY on Sunday, March 16, 2003 10:14 PM
In the book from Kalmbach, I believe it is called Tips and Techniques, it has a suggestion that a filter can be made by filling a gallon jug partly filled with water and fitted with a straw. You put the spray nozzle into the end of the straw spray. The fumes then go into the water where they are diluted and no fumes. I have not tried this but someone must have for it to be published.
