Wet sanding
    July 2003
Wet sanding
Posted by Daprophet on Saturday, December 27, 2003 9:59 PM
So, other than controling the amount of dust generated by sanding, what does wet sanding do?
God Bless
Dave
Posted by MikeV on Saturday, December 27, 2003 10:34 PM
It keeps the sandpaper from loading up with the material you are sanding as the water washes it away. Your sandpaper will last much longer and will cut better when wet.
Posted by Anonymous on Wednesday, December 31, 2003 8:26 PM
Does wet sanding apply to sanding sticks as well as to sandpaper?
Posted by Anonymous on Wednesday, December 31, 2003 11:27 PM
i think it does demondoc, also does'nt wet sanding reduce larger scratches in the paintQuestion [?]
Posted by dubix88 on Monday, January 5, 2004 8:55 PM
HEY,
How do you do it? Are there any special techniques?
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Monday, January 5, 2004 9:12 PM
Not all types of sandpaper and sanding sticks (nail files) are suitable for wet-sanding, check with the maker.
I tend to use fabric backed sandpaper or 3M sanding foam-pads (washable).
No special techniques, I keep a small bowl with water ready, dip sanding material and sand. At times i add the water directly onto the area where i sand.
We really need it on the Resin Kits, very fine dust that will collect in your lungs.[:0] Best to wear a mask when sanding resin.
Posted by Anonymous on Thursday, March 11, 2004 8:24 AM
Use a little dishwashing soap in your water, when wet sanding. I know this sounds funny but soap makes the water weter.
    May 2003
Posted by qmiester on Thursday, March 11, 2004 7:55 PM
crue leader
It doesn't make the water "wetter", just breaks down the surface tension (which causes drops on a surface). If you add liquid soap to water and apply it to a porous surface, the water will soak in deeper and quicker than untreated water. Fire departments add a chemical to water to fight fires which does the same thing. Funniest demonstration I ever saw was at a fire fighting seminar. They had 55 gallon drum of water with a duck swimming on top. Dumped a handfull of the chemical into the water and 2 seconds later the duck was on the bottom. And when they pulled it out, it was incredibly indignant.
Quincy
Posted by Anonymous on Thursday, March 11, 2004 8:00 PM
Here is another twist for wet-sanding.
Instead of Water use non-foaming shaving gel, works well.
Posted by rjkplasticmod on Thursday, March 11, 2004 8:31 PM
I usually won't wet sand with a sanding stick becuase the water may cause the stick to de-laminate, at least on the brand Iv'e been using. Been there done that.
Posted by Anonymous on Friday, March 12, 2004 3:54 PM
A little dishwashing liquid also acts as a lubricant to help prevent the "sanded off" paint particles from sticking in the sand paper and causing scratches. Quincy, here's a trick question for you. If you add wetting agent or surfactant (dishsoap in this case) to increase the "wet-ability" of water, doesn't that equate to making it "wetter"?
Cheers...Snowy.
Posted by dtraskos on Saturday, March 13, 2004 6:50 PM
Is water wet by itself or does whatever surface it is on become wet?
Posted by MikeV on Saturday, March 13, 2004 7:40 PM
That reminds me of the comedian Steven Wright when he said, "I bought some powdered water but I don't know what to add." Laugh [(-D]Laugh [(-D]
Posted by Anonymous on Saturday, March 13, 2004 8:13 PM
Thats easy Mike, basic chemistry, just add heat, the next Change of State will be from solid (powder) to liquid and hey presto! Instant Water!Smile,Wink, & Grin [swg]
Cheers...Snowy.
    January 2004
Posted by MusicCity on Saturday, March 13, 2004 9:45 PM
QUOTE: Thats easy Mike, basic chemistry, just add heat, the next Change of State will be from solid (powder) to liquid and hey presto! Instant Water!
Personally, I'd just stick it in the freezer. Let it freeze, and then when it melts you get water!
