base for models
base for models
Posted by Anonymous on Monday, December 29, 2003 2:09 AM
just wonder whats the best base for models and how do you perparie them do you like varnise them or what ?
as i would like to make some so i can diplay them in a shop
Posted by djmodels1999 on Monday, December 29, 2003 5:01 AM
I often use picture frames. It's cheap and usually already well varnished/coloured.
    May 2003
Posted by styrene on Monday, December 29, 2003 6:34 AM
Personally, I think the choices for bases is limited only by your imagination. I normally use a plain piece of semi-finished oak shelving. Because I normally put down ground cover made from Celluclay, I make sure I seal the wood with a good sealer. I personally like Minwax's Acrylic Polyurethane. Sealers are required to keep the wood from warping. I would advise staying away from pine or other soft, light woods if ground cover application is going to occur. Wood from trophy plaques also make good bases, as does plexiglas or even a piece of an old mirror. I've even seen bases made from ceramic tile. I had some trees damaged during Hurricane Isabel this past fall, and had to cut them down. I sliced some thin pieces (approx. 1 inch or so) of trunk from both a pecan and a poplar (8-10 inch diameter) and set them aside to dry in my garage in hopes of using them for some small artillery bases in the near future.
Bottom line: the possibilities are endless. Experiment and find something that you like that really complements the kit you've built.
Gip Winecoff
Posted by Anonymous on Monday, December 29, 2003 11:12 PM
ok thanks i think still a bit confused what about display case are thay just made frome clear plasitc
Posted by djmodels1999 on Tuesday, December 30, 2003 1:59 AM
Those are probably best made to order, depending on the size of your completed model.... Fujimi, Academy or Hasegawa (???) do sell 'generic' clear acrylic display boxes that are made for 1/24 cars.
