Drying Time for Oil Wash
Posted by Anonymous on Monday, December 29, 2003 4:06 PM
I did a wash with oils and turpentine and after 10 days it is still to damp to touch. Is this normal and how can I quicken this drying time some.
Posted by djmodels1999 on Tuesday, December 30, 2003 1:52 AM
It's quite normal. That's why oils are popular with figure painters... they allow for blending to be carried on days after application.
Is this a problem for what you're planning to do?
Posted by Anonymous on Tuesday, December 30, 2003 3:59 AM
not at all, I was just surprized it took THAT long:-) I have found that watercolor pencils seem to work well for weathering things, so I may just use them instead.
Posted by Anonymous on Monday, January 5, 2004 7:15 PM
Hmmm, 10 days you say?
I have never had an oil wash that was still wet after 48hrs. I would try cutting back on the amount of actual Artist Oils used.
Also, I would try 100% Mineral Spirits with the wash, instead of Turp. Maybe that is causing the slow dry time.
    December 2003
Posted by cbreeze on Monday, January 5, 2004 10:55 PM
Just my .02. You might want to try lighter fluid as the thinner. The capiliary acion is better and dries faster. I used Ronsonol lighter fluid. I think that's how it is spelled. Hope this helps.
Posted by Anonymous on Tuesday, January 6, 2004 3:47 AM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]
Posted by Anonymous on Tuesday, January 6, 2004 4:01 PM
What about meths (the stuff you filter through white bread before dinking..)?
Posted by Anonymous on Thursday, January 8, 2004 8:11 AM
The two usual mediums for pigment washes are alcohol and distilled water. Drying time is a few seconds to a minute or two. I suppose there are reasons for using other thinners but I can't imagine why.
Randy
    March 2004
Posted by DanCooper on Sunday, March 14, 2004 12:51 PM
I had a problem with drying time before too, so I placed the piece in a warm oven for a while.
Just make sure that the oven is not switched on anymore and that it is not too hot, if you don't trust this method you can also use a lightbulb as a heatsource.
On the bench : Revell's 1/125 RV Calypso
Posted by Anonymous on Wednesday, March 17, 2004 3:32 PM
Most oil paint manufacturors also make a additive to help quicken the drying time of oil paints. It works great. Check out an art store or craft store.
John
