Canopy Future Question
    December 2003
Posted by thevinman on Tuesday, December 30, 2003 9:23 AM
Two part question:
Does anyone out there future coat canopies AFTER painting and removing the canopy mask?
What is the best process for using future and masking canopies?
Posted by maddafinga on Tuesday, December 30, 2003 9:46 PM
I've only done a very few, but I always dipped them before painting. If you did it after painting, you'd have to remask to flat coat the paint to make it dull agian.
Usually when I use it, I just grab a part with tweezers, then dunk it in and swirl it around for a couple of seconds. I shake it off inside the containter (a ziplock disposable tub, very cheap) and then touch the puddles with a folded paper towel to soak them up. Lastly I set it down on a paper towel to dry (underneath another tub, to keep dust off). I do make sure to move it a couple of times the first couple of minutes to keep the Future from sticking to the paper towel.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
