Plastic polish
Plastic polish
Posted by Bones-coa on Tuesday, January 13, 2004 12:32 PM
Can anyone recommend a good plastic polishing compound? I intend to use it for both clear plastic and for polishing a NMF aircraft before painting. Is there something can get locally? Toothpaste perhaps?
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by maddafinga on Tuesday, January 13, 2004 6:34 PM
Novus worked really well for me on a screwed up aircraft canopy. It comes in three types, for badly and not so badly scratched, and one for finishing. It wasn't expensive and I got it at my LHS. Check yours and see if you can get some. I've heard that toothpaste works also, but given the types and brands available, it seemed a bit hit or miss to me. Smells nice and tastes good however.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Tuesday, January 13, 2004 7:16 PM
Tamiya markets their own plastic polish just for this purpose, it comes in a small tube and sells for about $5 here in Oz (probably $2 or $3 US). Works great for removing small scratches and getting a mirror finish.
Cheers..Snowy.
Posted by Bones-coa on Tuesday, January 13, 2004 7:24 PM
Thanks guys. I'll look into both of these.
Posted by Anonymous on Tuesday, January 13, 2004 7:34 PM
Over here on the market we can get plenty of different polishing compounds.
I think Tamiya is going to be issuing a new reange of polishing compounds that are now rated according to their griddiness.
My favorite is Top Compound 2000 or similar.
    September 2003
Posted by checkmateking02 on Friday, January 16, 2004 3:09 PM
Bones:
you can also use toothpaste, as long as it is NOT the gel type. Polish is hard to come by locally, so I regularly use toothpaste. I buff it with an old T-shirt; wash it off and it usually works fine--even on clear parts.
Posted by Anonymous on Friday, January 16, 2004 8:02 PM
We used brass polish to polish plexiglass to a crystal clear surface..
Posted by Anonymous on Tuesday, January 20, 2004 8:14 PM
anyone know if the Tamiya polish is available in the UK Question [?], i'm drawing a blank over here, toothpaste is not giving the results i've seen from the Tamiya product.......Dead [xx(]
Posted by Anonymous on Wednesday, January 21, 2004 10:57 AM
Here is a trick you might want to try. Next time you are in the grocery store, go to the aisle with the fingernail polish and supplies. There you should find nail buffing boards for about $2 - $3 each. They usually have 3 or 4 grits on a board, which makes them a pretty cheap solution to your scratch problems. These are very similar to the Squadron sanding boards that cost easily twice as much.
These little buffing boards work wonders on aircraft canopies, leading edges of wings and fuselage seams. As an added bonus, there is no residue left on the plastic to interfere with painting.
    July 2003
Posted by KJ200 on Wednesday, February 4, 2004 3:30 AM
Scooter_roo's trick with the nail boards is a winner.
I saw the Squadron sanding sticks in LHS recently, at about £2.50 a shot, or about $4.25.
Trip to a local pharmacist saw me picking up a multi grade stick for £1.20, or $2!!!!!
Used it for the first time on my 262. Absolutely brilliant. Joints and seams dissapear completely leaving a polished surface ready for painting.
Well worth trying.
Karl
