small parts
small parts
Posted by Anonymous on Wednesday, January 14, 2004 5:25 PM
I am a fairly decent modeler. I clean seams, putty seams, sand imperfections, all that good stuff. But I cant seem to get small parts off the tree easily and if i do, i usually snap them while trying to clean them. How do you get peices off the sprue and onto your models in one peice?
Posted by Anonymous on Wednesday, January 14, 2004 5:35 PM
I use a 180 Degree electrical wire cutter and a scalpel with disposable Blades for cleanup.
Also when cutting the parts off the sprue I check first for possible stress-points that might snap the part is cut off in the wrong sequence.
Either way don't excert too much force(ie, cutting of with a Knife, etc), rather cut closer to the sprue than the part, you can always clip the attached sprue easier of once the part is seperate.
For really tiny parts(1/35 Rivets, 1/24 hood clasps, etc) I either use tweezers or gently skewer them on the tip of a #11 Blade and position the part that way.
    May 2003
Posted by styrene on Friday, January 16, 2004 6:05 AM
Micromark has small razor saws in the shape and size of #11 X-acto blades, and they come in a set with various tooth sizes. These things are invaluable in removing small delicate parts.
One other thing you can do is get a small chisel blade for your X-acto knife handle. Hold the part firmly on a hard surface and press the chisel blade vertically onto the attachment point. Should cut clean for you.
Gip Winecoff
Posted by Anonymous on Friday, January 16, 2004 2:59 PM
Lesson learned the hardway #1002. When removing verrrrry small parts from sprues make sure you have a good grip on them. One thing that works for me is to use masking tape so that the part doesn't get launched into the air, never to be seen again. I put a strip on the sprue, on the side opposite of which I am cutting, making sure the part is gripped by the tape before I cut. Then I remove the separated part from the tape with tweezers. I use cutting pliers with a flush face to remove all my parts.
    September 2003
Posted by checkmateking02 on Friday, January 16, 2004 3:12 PM
You can also try making a cut on both sides of the sprue, where the part attaches; it sometimes makes the part easier to get at, when it is separated from the larger "tree."
JR
Posted by Anonymous on Monday, January 19, 2004 8:13 AM
First Timer.
What is the best way to construct individual links for a track. I'm building the Tamiya FAMO 18-ton half-track
