Paint first or last???
    September 2003
Posted by KevinCollins on Tuesday, January 20, 2004 8:58 PM
Hey Gang,
I see all these great models in magazines and they say that they were airbrushed after assembly (including painting different colors for different parts of the model). I wanted to know what is the best way to do things...1) Paint first then assemble....2) Assemble then paint....3) Paint small parts by hand, assemble and then airbrush...major assembly....
How do you guys do it? I have yet to use an airbrush so maybe that is part of my dilemma...not knowing how precise they are. How much masking is involved (depending on technique)? Any suggestions on how to do it would be great.
Thanks
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
    January 2003
Posted by CNicoll on Tuesday, January 20, 2004 9:26 PM
Hey Kevin, You will get LOTS of great advice, but let me give you my 2 cents worth just to get you going.
First, get an airbrush and a kit to practice on. Like any tool, it will take some practice to use it well, but you will very quickly come up to speed if you jump over to the airbrushing forum here and read some of the posts. There are some great folks here.
I paint the interiors and sub assemblies first: cockpits, engines, suspension parts, etc. I do the exterior last since I am usually closing fuselages up. In general, I paint whenever its easiest and is the least likely to get messed up during assembly (or will be easy to touch up later).
There is no right or wrong answer, so good luck!
Chris
On the bench:  Academy 1/72 B-17G 'Blue Hen Chick';  1/48 Tamiya Mustang III; Kitty Hawk 1/32 P-39.
Completed:  1/48 Tamiya P-51D Mustang - 'Show Bird', 1/32 Dragon P-51D  Flying Tigers 'What if'; 1/32 Tamiya P-51D Big Beautiful Doll
Group build:1/48 Tamiya Mustang III; 1/48 Tamiya P-51D Show Bird
Posted by Anonymous on Tuesday, January 20, 2004 9:40 PM
On nearly all kits parts will be needed to be painted first or last, it really depends on the area of the kit you are working with.
Some things will NEED to be painted first while others can be painted later, there is no rule or guideline for it. Study the instructions well, testfit a lot and many things will become clear as to painting and assembly sequence.
An Airbrush will not make a difference on the painting sequence nor will it guarantee a better finish.
IMHO, too many people are airbrush obsessed and believe that they cannot build a nice model without one.
    December 2003
Posted by thevinman on Tuesday, January 20, 2004 10:03 PM
I usually paint the interior/cockpit first. Then I assemble and paint the landing gear, guns, turrets, canopy...whatever extraneous details there are. At the same time, I close up the fuselage and build the wings and tail. I check for gaps/seams and putty them if necessary. I then paint the main structure, and last I attach the rest of the doo-dads that were pre-painted. There are all sorts of details/steps I left out. (priming, masking, future, decals, dull-cote etc.) But that’s my process, in a nutshell.
Airbrushes are nice, but for years I used spray cans and the almighty brush. With decent masking and painting techniques, you can accomplish almost everything an airbrush does for you. (but I still love my airbrush…)Big Smile [:D]
    August 2003
Posted by South Aussie on Tuesday, January 20, 2004 10:36 PM
Kevin,
There has been a lot of discussion on whether to paint first or last regardless of whether you air brushing or hand painting, it really depends on the model, it is always wise to check the instructions before building to work out , what parts need to be painted before assembly, are there areas that can be painted as an sub assembly.
As Chris said there is no right or wrong answer to this question.
Wayne I enjoy getting older, especially when I consider the alternative.
Posted by Anonymous on Wednesday, January 21, 2004 8:31 AM
I'm still a rookie at this but just a bit of experience and common sense goes a long way. I just always think of the next step I'm gonna take. If it involves sanding or puttying, then I wouldn't even try painting cause sanding will just ruin the paint job and hence I would paint again anyways. Most will probably say, paint the interior first, cause you won't be able to get at that later with precision. All these decisions is what makes the final results the most satisfying.
    May 2003
Posted by nsclcctl on Wednesday, January 21, 2004 12:26 PM
I paint interior, then assemble plane. I mask off the interior and airbrush the camo scheme or what-ever. I then go back and add small parts and do any weathering I choose to do. I use to paint all parts first but it was a nightmare, especially with camo and keeping things straight.
    September 2003
Posted by KevinCollins on Wednesday, January 21, 2004 3:41 PM
Thanks everyone....I usually paint the small stuff first and then assemble them (ie..interiors)...then the outside details (ie..tools....guns...)....(all being done by hand)......then mask and paint the body (or main part of the model) with spray can or by hand or airbrush (I do have one)...it seems though that in the magazines people are doing small details with the airbrushes....tools...wheels etc...(I usually do 1/35 tanks)...I usually mask off the mounting area for those tdetails (tools...etc) on the model, paint the whole thing then go back and glue on the details....it works for me but was interested in what others do
