Seatbelt Material
    January 2004
Seatbelt Material
Posted by MusicCity on Wednesday, January 28, 2004 6:03 PM
I found several suggestions for making seatbelts, all of which were very good ideas. I did find something that wasn't mentioned that seems to work pretty well to. It isn't very politically correct these days though Smile [:)]
I used the foil from a pack of cigarettes. It's thin enough to go through 1/32 photo-etched buckles, but stong enough to stay in one piece. It's also textured so it gives the seatbelts a more realistic look. I used it with the white side out, not the foil side. If you need it thinner I think the paper can be shaved off the foil (or maybe just soaked off), but I didn't try that.
Posted by Anonymous on Wednesday, January 28, 2004 10:47 PM
Damn, I knew I shouldn't have quit smoking!!! HONEY.......I NEED to smoke for my models!!!!Tongue [:P] AHHH, she ain't buying it. Thanks for sharing, I'll keep it in mind if I ever start up again!!
    January 2004
Posted by benzdoc on Thursday, January 29, 2004 9:44 AM
where's a smoker when you need one? :)
    November 2003
Posted by shrikes on Thursday, January 29, 2004 10:15 AM
That's a great idea! Hey, what other smoker's paraphernalia can i use to justify this disgusting and expensive habbit? Wink [;)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    January 2004
Posted by MusicCity on Thursday, January 29, 2004 4:50 PM
Here's what they look like. The photo actually shows the texture if you look close.
Gotta work on the colors a bit though. Fluorescent lights make it look greener than it actually is.
Don't worry, I've always got a stack of extra foil laying around here Big Smile [:D] Let me know, I'll send you some.
Posted by Anonymous on Monday, February 2, 2004 4:23 PM
Wow great idea and look at those seatbelts, they are just amasing, I should try that!Big Smile [:D]
Posted by Anonymous on Tuesday, February 3, 2004 11:17 PM
I've used standard yellow masking tape, two pieces stuck together so there's no sticky side, cut into thin strips with an X-Acto. Fine wire for the harness rings, Koch fittings, etc, and a dab of superglue to hold the strap in place. Paints nicely with enamels.
Posted by Anonymous on Wednesday, February 4, 2004 12:36 AM
Hey MC.
How did you make your buckles.
I am busy with the seatbelts for my 1/24 BF109 G2 and man, I just can not get the buckles right.
I have tried everything.
Rudie.
    July 2003
Posted by KJ200 on Wednesday, February 4, 2004 3:19 AM
I use the foil off the top of wine bottles..........
........does this men you need a vice, be it drinking or smoking to be able to model seatbelts properly?
Those people at Eduard sure must get through a lot of cigarettes and booze!!!!LOL.
Karl
    January 2004
Posted by MusicCity on Wednesday, February 4, 2004 5:19 AM
QUOTE: Wow great idea and look at those seatbelts, they are just amasing,
Thanks T-34, glad you like them Big Smile [:D]
QUOTE: Hey MC. How did you make your buckles.
They came with the kit and are photoetched parts. They look good, but were a pain to work with.
QUOTE: does this men you need a vice, be it drinking or smoking to be able to model seatbelts properly?
Modeling IS a vice!! Wink [;)]
QUOTE: I've used standard yellow masking tape, two pieces stuck together so there's no sticky side, cut into thin strips with an X-Acto
I didn't try that, but I did take a piece of an old shirt painted with Future to give it some stiffness, I tried heavy paper, and a couple of other things. None of them would go through the buckles because they were too thick. Regular paper worked but I tore it trying to get a buckle on. Finally came up with the foil idea and managed to get through the ordeal.
Posted by Anonymous on Wednesday, February 4, 2004 9:19 PM
I bought a photoetched seat of seat buckles from Detail Masters and it has thin paper included that worked really well. Just color it with a sharpie.
    January 2004
Posted by MusicCity on Thursday, February 5, 2004 8:36 PM
Mine came with paper seatbelts printed on the instruction sheet. They didn't last long; tore the first one, tore the second one, waded the third and forth up and threw them away; went looking for something more substantial that I wouldn't screw up so easily.
    July 2003
Posted by KJ200 on Friday, February 6, 2004 3:19 AM
Modelling is not a vice!
It's therapy!
Karl
Posted by Anonymous on Wednesday, February 11, 2004 12:53 AM
KJ200
I have tried the wine thing, but man no go...
How do you get the 2 gaps in the buckle for the belt to go through.
Please tell me how...
Rudie.
