tips
tips
Posted by dubix88 on Tuesday, March 11, 2003 1:46 PM
hey. im lookin for ANY tips on building plastic model cars and how to make them look better. ANYTHING i can do while building it to make it look better. Thanks. E-mail me at dubix88@yahoo.com
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Tuesday, March 11, 2003 7:03 PM
dubix88
I'm going to say this to beat Dvoss to it. Kalmbach Publishing has many fine how to books that would be good to start with. There are so many things that could be said aout this matter. Reading some books on the basics will help.
That being said I'll start the ball rolling with this.
1) cut the parts off the sprues. Don't twist or pull them off, that will damage them. If there is still a little piece left over, remove it with sandpaper or a file.
2) Remove any seam lines or flash from the parts before painting. Sandpaper, file, exacto blade or seam tool will do the trick.
maybe someone else will chime in
Darren
Posted by berny13 on Tuesday, March 11, 2003 10:23 PM
Dont rush, take your time. If things start to go wrong or something doesn't want to fit, take a break. Get something to drink or take the dog for a walk. After you get back to it you will be in a different frame of mind.
Fit everything to check for proper fit and alignment prior to glueing. Do any sanding or fileing before glueing.
Work SAFELY.
Berny
 Phormer Phantom Phixer
On the bench
Posted by cnstrwkr on Wednesday, March 12, 2003 9:24 AM
trial fit as many parts as you can before you glue, modeling tips are endless and browsing here should help. Good luck and have fun Big Smile [:D]
Tommy difficult things take time...the impossible, a little longer!
