Cleaning parts before CA
    November 2003
Posted by Copterguy on Wednesday, February 11, 2004 3:59 PM
Hey folks,
I haven't used CA glue on painted parts before. Is it necessary to remove the paint first like with liquid cement or does the CA penetrate the paint regardless? I'm attaching a whole pile of small painted parts to a tank (tools, etc.) and I would rather avoid a lot of little scrapes before gluing.
Many thanks.
Jim
Current Projects: Tamiya M1A2 Tamiya LRDG Chevrolet CWT 30
Posted by MikeV on Wednesday, February 11, 2004 4:27 PM
CA will glue parts that are painted without a problem, although it can cause the paint to smear a bit if you use too much.
    May 2003
Posted by qmiester on Wednesday, February 11, 2004 6:37 PM
As Mike said, the CA will attach the part to the paint. The only thing that I have ever really noticed is that I usually have to do some touch up because most CA dries glossy.
Quincy
    November 2003
Posted by Copterguy on Wednesday, February 11, 2004 6:41 PM
Thanks guys - this should make things a little easier.
Jim
Posted by Anonymous on Wednesday, February 11, 2004 6:47 PM
I prefer to clean the parts before applying any form of glue.
Said that in many cases I had to glue painted part(Hair strain)to painted part(Face) during my resin kit building.
I don't often use CA is I find it creates a hard brittle joint that can easily be snapped apart again and does not work well for weightbearing joints.
Posted by MikeV on Wednesday, February 11, 2004 10:45 PM
I agree with you there MMF. I like to use it to put weapons under the wings of aircraft as it is quick and if a small drop is used it is not visible either.
