Dry brush color for white base
    December 2003
Posted by cbreeze on Thursday, February 12, 2004 4:58 PM
Greetings,
I think I have a understanding how dryburshing is supposed to work. Lighter shades on darker base, darker shade on lighter base. I am having a little trouble dry brushing a white base and getting it to look right. On my current project I am painting the wheel wells white. Did a wash and want to high light but can't decide on a drybrush color that would look right. Anyone have any ideas on what you would use? Thanks in advance.
Posted by Anonymous on Thursday, February 12, 2004 5:13 PM
If your base coat is pure gloss white, there's not much you can do. If its flat white, you can dry brush gloss white or Future. Another solution is to paint the base coat slightly off-white (add a MINUTE amount of black or pure gray to the white - you don't want to turn it gray, just alter the value of the white slightly). It will still look white, but the dry brushed white will be lighter. Just an idea.
Hope you find something that works for you.
Posted by Anonymous on Thursday, February 12, 2004 6:33 PM
Any surface that has depth or relief, even if white, is going to produce shadows and highlights. I would give the area a weak wash of either Sepia or black-brown, followed by a light dry-brushing with titanium white oil paint. If the overall effect appears too stark, you can always tone it down with light colored or light gray pastel chalk. But make sure the oil paint is bone dry before using the pastels.
Posted by ajlafleche on Friday, February 13, 2004 1:01 PM
Also, you can start you color with a very light gray, such as Vietnam era underside camo gray. Give in an approproaie wash and drybrush with white.
Posted by BlackWolf3945 on Sunday, February 15, 2004 5:36 PM
My technique is to paint everything black, no matter what the color is going to be. That's my shadow.
Then I go and lay in the color (spray), leaving the appropriate shadowy areas darker.
If it's a dark color I'll add highlights by drybrushing with lighter shades of the base color and re-justify any lost shadows with either washes or pastels.
If it's a light color, the highlights are already there and there's usually little need for drybrushing, depending on the actual color. I'll simply enhance the shadows with washes or pastels and add additional highlights, only if necessary, again, with a lighter shade of the base color.
Fade to Black...
