detonating cord on canopies
Posted by wibhi2 on Friday, February 13, 2004 8:23 AM
what's the best way to replicate the detonating cord on jet canopies?
3d modelling is an option a true mental excercise in frusrtation
Posted by BlackWolf3945 on Sunday, February 15, 2004 5:23 PM
Never have done that myself, but I've thought of using .010 solder wire bent to the appropriate shape, perhaps slightly flattened out, painted and attached with a tack-adhesive. It may be a bit overscale and would take a bit of time to get the right shape and all, but solder is fairly easy to work with and I think it'd look dang good.
Fade to Black...
Posted by wibhi2 on Monday, February 16, 2004 11:05 AM
I was beginning to think along the same lines. I came across some 34 guage beading wire that may be more to scale for 1/48th
Thanx
Posted by BlackWolf3945 on Monday, February 16, 2004 12:42 PM
Beading as in... jewelry? What's the actual diameter of that stuff?
Fade to Black...
Posted by wibhi2 on Tuesday, February 17, 2004 4:03 PM
yep it's jewelry wire. Found it while buying my daughter some foam core.
It looks to be under an inch (bet 1/2" & 3/4") in diam. in 1/48th scale. My calipers has it just under .01
