Aluminum or brass tubing for 1/48 Skyraider barrels
Posted by MikeV on Sunday, February 22, 2004 7:42 PM
Is the 1/16" aluminum and brass tubing small enough to replace the cannon barrels on a 1/48 Skyraider kit?
Thanks
    May 2003
Posted by qmiester on Sunday, February 22, 2004 8:22 PM
Mike,
When I built my Monogram A-1 several years ago, I measured the kit weapons with a set of dial calipers and used the K&B tubing that was closest (couple of thousands larger). Not sure but think it was the 1/16" and it came out looking pretty good.
Quincy
Posted by MikeV on Sunday, February 22, 2004 9:24 PM
Thanks Quincy.
I have only seen the tubing online so I was unaware as to how it looked in person. I will have to locate some around here.
    January 2004
Posted by MusicCity on Sunday, February 22, 2004 10:30 PM
Scale-wise it's going to be a bit big outside. 1/16" tubing is 0.0625 OD which would equate to 3" diameter at 1/48 scale. The inside diameter is too small for me to measure, but I'd say it's around 1/32" or less. That would equate to 1-1/2" at 1/48 scale, or about a 38mm (or less) bore. If they had 30mm cannon you are in business. Even if they had 20mm I don't think you'll get alot closer.
I've got 3' of it downstairs. How much do you need? Big Smile [:D]
Posted by MikeV on Sunday, February 22, 2004 11:11 PM
Scott,
The aluminum tube that Micro-Mark sells lists it as the following:
1/16 inch O.D., .014 inch wall.
I only need about 6" of it at the most. Does anyone make it smaller than 1/16" without having to find hypo needles?
    January 2004
Posted by MusicCity on Monday, February 23, 2004 5:17 AM
These guys have it down to 0.0058 OD, but you pay for it to because it's stainless steel hypo tubing!
http://www.smallparts.com
6" of HTX-22 (which has an ID of 0.016" that should correspond to 20mm at 1/48 scale) is $1.70!
Posted by MikeV on Monday, February 23, 2004 7:08 AM
Scott,
Thanks for the link. Thumbs Up [tup]
I had seen this web site in the past but had forgot about it.
I wish their shipping prices were lower though as $8.95 for a piece of tubing is outrageous. [:0]
    January 2004
Posted by MusicCity on Monday, February 23, 2004 7:54 AM
QUOTE: I wish their shipping prices were lower though as $8.95 for a piece of tubing is outrageous. [:0]
Oooowwwwwww .... I didn't even notice that. You are right, Mike, that is absurd. Sure raises the price per inch for those cannon barrels!
    May 2003
Posted by styrene on Monday, February 23, 2004 10:50 AM
Mike,
Your order to them also has to be at least $20. I ordered several different varieties of tubing for the 40mm and 20mm guns for the Missouri I'm trying to piece together. The tubing is beautiful, though. I ordered in 2 and 3 foot lengths, and the stuff came packaged in nice plastic tubes. If you didn't live 3,600 miles away, I'd go in with you on an order...
Gip Winecoff
Posted by MikeV on Monday, February 23, 2004 7:29 PM
Thanks Scott and Gip.
I am going to try and find some around here as there has to be some in this area. We do have the Silicon Valley here you know. Big Smile [:D]
Maybe one of the bigger LHS like San Antonio Hobbies would have this tubing.
If not, I may just order several sizes of the tubing from "Small tools" to make the shipping worth the price. I will need the tubing for .50's on the P-40 as well as most all of the WWII aircraft, so I will need a few feet of that. Wink [;)]
Posted by MikeV on Saturday, February 28, 2004 6:53 PM
QUOTE: Originally posted by styrene
Mike,
Gip,
Their web site says, "No minimum order" in the terms and conditions section.
