A modeler on the 'fence'
Posted by Anonymous on Thursday, February 26, 2004 11:29 AM
I have been having troubles with the Fencing method of applying putty to seams. I have used normal Masking tape, and I have used Tamiya's masking tape. In either case, when I smooth down the putty with the Q-tip and nailpolish remover, I get extra putty left on both sides.
Then, when I have finally cleaned it up, I end up removing the putty from the seam I was trying to fill!. Angry [:(!]
Does this just take practice, or am I missing something?
    December 2003
Posted by thevinman on Thursday, February 26, 2004 12:00 PM
Check out http://www.swannysmodels.com/Seams.html
You should be applying the tape, then the putty, and then removing the tape BEFORE the putty dries up too much. Then, you use the nail polish remover to smooth it out.
Just in case I misinterpreted the question and you ARE doing it in this order, I would suggest trying to remove the putty from the sides first. What I mean is, don’t wipe the seam…wipe to one side, then the other. This way you will be working in toward the seam and leaving most of the putty where it should be. Then, when the sides are cleaned up, wipe down the seam to the desired level. This may take some time, so don’t rush.
Plan B would be to break out the ol’ sandpaper and sanding sticks and do it the traditional way.
Posted by Anonymous on Thursday, February 26, 2004 2:47 PM
It looks like tradition. When I pull up the tape after laying as thin a layer of putty as I can, I have this "cake" of putty right on the seam. It is all nice and clean on both sides. I then "moosh" the putty down with the q-tip (again following procedure). This spreads the stuff outward and I have to clean up.
    December 2003
Posted by thevinman on Thursday, February 26, 2004 7:41 PM
After you remove the masking tape, let the putty dry before you do anything to it. The Q-tip with nail polish remover will slowly remove dried putty. You shouldn't be "Mooshing" anything once the tape has been removed.
Posted by Anonymous on Wednesday, March 3, 2004 8:40 PM
Well here's MY traditional way of doing it....
Make the fences out of tape...
Cover the seam with putty
15 mins or so later remove the tape
WAIT TILL THE PUTTY IS DRY
start sanding putty
By the way, I think the nail polish doesnt work with Tamiya Basic putty (stuff I use)
    December 2003
Posted by thevinman on Thursday, March 4, 2004 6:45 PM
Exactly,
And by the way – I use Squadron white putty, most of the time, and acetone based nail polish remover works on that brand.
