how make metal like finish?
Posted by Anonymous on Saturday, February 28, 2004 3:04 PM
I´m finishing a Gloster airplane and I want finish it llike silver metal.
I believe that the process would be:
1) silver spray paint
2) polish with silver metal dust (poulder)
3) and here is the problem, If I apply a gloss varnish over the silver powder will the metal finishing be lost?
Thanks
Carlos
    November 2003
Posted by shrikes on Saturday, February 28, 2004 9:16 PM
Firstly, welcome to the forums, cesege! Hmmm... I don't think i've ever heard of silver metal dust before, but i'm pretty sure some one here can help you. I use plain old rattle can colors after the model has been primed. They say you should under coat with flat black first then spray on silver/aluminium.. You can also try Bare Metal Foil.
Hey, why not join the Natural Metal Finish Group build in the Aircraft forum, there are a frew guys who are sharing techniques over there! Smile [:)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    May 2003
Posted by qmiester on Monday, March 1, 2004 8:46 AM
cesege
Again, welcome to the forum. I'm not sure about poulder, but I'm assuming its like SNJ, that is you apply it to the area you want it with a soft brush or q-tip and then polish it to the sheen you want with a cotton ball. If this is the case, you should have no problems applying a gloss coat over it.
My suggestion would be to take an old model (or buy a cheap model and assemble it) and try what you want to do on it. That way you can find what works with out damaging your Gloster. Word of caution on aluminum paints (whether applied from a rattle can or air brush), you will find that almost all aluminum paints (except for Alcad II) will lift if masked over with regular masking or modeling tapes. To overcome this (especially on those panels that you are applying the poulder to) you can mask with Post-it Notes or damp newspaper, both of which work very well and won't lift the aluminum paint under them.
Quincy
Posted by Swanny on Thursday, March 4, 2004 11:31 AM
I would go with Alclad. I have done 5 1/48 aircraft with various shades of Alclad and am very happy with the ease of application and the final results.
