Whiteout to replace weld seams
Posted by wjbwjb29 on Saturday, May 31, 2014 12:30 PM
Hello;
I used water based whitout to replace some sanded of weld seams on my AFV Club Uboat and they turned out very nice. Couldnt get any thing else to work on such a small model, I got the model primed and am now concerned about masking over the seams. Will it pull off, I will be using Tamiya tape. I primed with Floguil solvent based paint.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    September 2007
Posted by SuppressionFire on Saturday, May 31, 2014 2:40 PM
Now its painted thin styrene strips would not work as well if onto bare plastic with styrene solvent cement.
Obviously it a small scale, 1/144 or smaller? The primer is flat so strips of paper could be applied with diluted white glue. It can be re-softened to work in some texture or repositioned. Once the top coat goes on it will seal the paper into the paint.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
Posted by wjbwjb29 on Sunday, June 1, 2014 10:47 AM
I tested it on bare sprue, something I should have done before using it. It aheres very well. I dont think regular masking tape would pull it off. If anyone knows what this stuff is made I sure would like to know.
Bill
    May 2003
Posted by qmiester on Saturday, June 28, 2014 6:02 PM
I've found that liquid White Out works great for sealing small seams and the divits caused by shrinkage caused sometimes when styrene cools when removed from the mold.  Simply apply to the damaged area, let dry for 5 minutes or so and sand smooth.  Doesn't shrink after it dries and doesn't seem to react to enamel paint (the paint of my choice)
Quincy
    November 2003
Posted by mississippivol on Saturday, June 28, 2014 8:41 PM
Cool tip!
    December 2011
Posted by Chrisk-k on Saturday, June 28, 2014 10:19 PM
White-out works well for filling *tiny* seams and scratches.  It tends to crack later if applied to a large area.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Don Stauffer on Sunday, June 29, 2014 11:11 AM
I have used white glue for weld seams- it is a little thicker than white out.  I apply with a toothpick.
