Fingerprints...
    June 2014
Fingerprints...
Posted by Matt-Joachim on Wednesday, July 9, 2014 6:21 PM
   I know prevention is the best method. However, no matter how careful I am with my glue(usually gluing fuselage halves together) sometimes I will end up with a glue fingerprint on my model. I try to wipe it away as soon as i can, but sometimes I overlook one. Basically my question is: How do I remove dried fingerprints from a plastic model? It is usually on the bare plastic but sometimes on the paint itself. Sand it and start over? IDK?!
    November 2003
Posted by mississippivol on Wednesday, July 9, 2014 6:38 PM
Yeah, you will probably have to sand it out. Prevention is the key, and in my 37 years of modeling, I still have the occasional glueprint show up.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, July 9, 2014 11:36 PM
Try latex free disposable gloves.
    July 2004
Posted by stikpusher on Thursday, July 10, 2014 12:05 AM
I still have it happen from time to time... I sand it away carefully with a fine sanding stick,
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Bish on Thursday, July 10, 2014 1:19 AM
Same here, happens to me now and again. Using plastic weld, I sometimes find it has eastern into the plastic which means to has to be filled then sanded.
    November 2010
Posted by Eagle90 on Thursday, July 10, 2014 5:56 AM
You are not alone!  It happen to me the other day....again!  Embarrassed  Best bet, let it dry, then like everyone else has mentioned, just lightly sand it until you are happy with it.  Or, if it doesn't go away completely, do what I do.........WEATHER THE CRAP OUT OF THE BUILD!  Whistling  Just sayin'!
Eagle90
    June 2014
Posted by Matt-Joachim on Thursday, July 10, 2014 7:36 PM
Thanks everyone! Unfortunately that is what I was thinking :(
and Blacksheep, I have tried gloves...it solves the fingerprint problems but the gloves still leave a glue smear! Thank you all for being so helpful! Like I said I assumed prevention is the only true fix i could think of. I have a long way to go, but I am making good progress on my BATCH builds lol im addicted to building several kits at the same time :D
    February 2007
Posted by mitsdude on Thursday, July 10, 2014 9:05 PM
Hazard of the hobby.
I've had builds where I had to sand/repaint 5-6 times because of fingerprints or fingernail scratches.
Aaaaaarrrggg!!!
    December 2011
Posted by Chrisk-k on Saturday, July 12, 2014 10:31 PM
When I see a fingerprint or any imperfection on a model that I'm building, I simply weather that spot by applying pigments.  In other words, I turn imperfections into features.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    January 2013
Posted by jibber on Wednesday, July 16, 2014 7:34 PM
If its in a tight spot I'll use my Xacto knife by scraping it away (lightly) until its gone then lightly sand it. I find doing armor theres more little tight spots. Sometimes I get a little "bleed through" like when I glue on a hatch from inside the turret and some amazingly seeps out. Open areas I'll sand em. Most times less is more, I try to use as little glue as possible, hope you get some answers here. Terry
    June 2010
Posted by OctaneOrange on Monday, November 3, 2014 5:16 AM
i've tried that. not only does it not stop glue transfer (only stops it getting on your finger, not the model) but it's hard to do fine work with them on.
    December 2006
Posted by Fly-n-hi on Monday, November 3, 2014 8:09 AM
If you do get a fingerprint or some other glue smudge on the model don't try to wipe it away.  Just let it dry then sand it lightly afterwards.  Trying to wipe it off or down just makes it worse.
