Frosted Canopy sections and Windows
    August 2008
Posted by tankerbuilder on Friday, January 23, 2015 2:27 PM
Hi;
      I have been using this on H.O. scale ( 1/87 ) trains . If you don't have the inclination to detail a cockpit or want to look through your latest air - liner kit this is for you .
    Using a Fresh bottle of testors glue and a sprayer from the ubiqutus spray bottle of Zip Kicker , you can frost windows and canopies INSIDE and get a smooth , blemish free finish which you can't see through .
       You do this . Make sure the plastic you are treating is clean and dust free . You can , using a wide fan type brush achieve this on flat surfaces . For all others use the spray .One squirt at about six inches is all you'll need . Not a heavy squirt either . I have been using this on 1/48 scale and H.O.scale ships where the client wants no interior for years now .
      Try this , and I think , if detailing a cockpit or plane interior isn't your thing , you'll really like the effect .   Tanker - Builder                 P.S. You can use this on cars and soft -skin armor vehicles too .
    August 2012
Posted by JMorgan on Saturday, January 24, 2015 4:36 AM
Will lacquer clearcoat work too?
    May 2004
Posted by cbaltrin on Saturday, January 24, 2015 7:09 AM
I would think flat coat would do the trick
Atomizing liquid cement does not seem like a good idea to me! :-)
On the Bench: Too Much
    October 2010
Posted by hypertex on Saturday, January 24, 2015 7:55 AM
A clearcoat won't have the same effect (if I understand tankerbuilder's post correctly). A clear coat will leave the canopy clear, maybe a bit frosted if a lacquer is used. TB is describing a technique that turns the canopy opaque, which means you can't see through it.
Liquid cement is just a solvent--when it evaporates it leaves nothing behind (except for small amounts of impurities). So I don't think that atomizing a liquid cement would be a whole lot more dangerous than atomizing lacquer thinner. I would, however, think it prudent to use the same precautions as painting--have good ventilation, use a respirator, wear gloves, etc.
But if I'm going to go to that much trouble, why don't I just paint the inside of the canopy with acrylic white or something?
Posted by Don Stauffer on Saturday, January 24, 2015 9:48 AM
I have sometimes sprayed dullcoat on a canopy to weather it and help make the model into a ramp queen.  Especially with older planes, say WW2 era, they were not UV-stabilized   as well as modern stuff, and too many days in sun would fog them up pretty good.
    August 2008
Posted by tankerbuilder on Tuesday, January 27, 2015 9:13 AM
It does
But I don't recommend it for regular use.
    August 2008
Posted by tankerbuilder on Tuesday, January 27, 2015 9:16 AM
Hi ;
   Actually , you don't have to go to extremes on protection . Just , DO wear the mask and gloves , Five for five . Five minutes of putting the stuff ,  on for Five minutes of protection ,. Good trade - off I think .
