Cleanly scaling up blueprints/etc.
    February 2015
Posted by KeithFromCanada on Sunday, February 1, 2015 5:35 PM
I saw that someone was tracing low-res blueprints in AutoCAD, and I felt his pain, as I've had to deal with that a number of times in the past.  Fortunately, there are some new software tools available to help with that.
A long while ago, I evaluated some software for a client to resize pics without losing detail, and find that Genuine Fractals 6.0 ($160), PhotoZoom Pro 2 ($240), and Image Enlarger 0.8 ($0) do an amazing job of producing sharp, clear enlargements, as can be seen in this comparison of a 64×64 sample enlarged to 256×256 (4x):
For rescaling high-contrast/non anti-aliased images by 2, 3, & 4 times, however, there is simply no better algorithm than HQx (Code page)
Which one will work best for your project will depend on what kind of source you have, but I've found both the SmillaEnlarger and HQx to work wonders when the artwork I have to trace is just too small on its own.
Hope this helps!
Posted by Don Stauffer on Monday, February 2, 2015 8:59 AM
I have found it is not really a problem.  I make a new layer for my CAD lines, and as long as you do a good job on that layer, you can "turn off" the layer the tracing is on.  Usually the eye can smooth the low res trace image pretty well without having to artificially upsample it.
