Instructions , Not a bible .
    August 2008
Posted by tankerbuilder on Monday, March 23, 2015 12:53 PM
Hi :
    How many of you swear by the instructions from beginning to end ? I bet you've never built a TRUMPETER 1/350 large ship then . If you did , you would know there's a Glaring flaw in the build steps .
   I'll bet Don Stauffer wouldn't build a ship from the deck up and then put the hull on . With all the top work on , how are you supposed to do that ?
    This may sound funny , but TRUMPETER , on more than one ship model , has you build the top of the ship to a point and then turn it over to install the Hull Plate ( waterline ) or Bottom at this time . Thing is , with the masts and radars on say the NORTH CAROLINA battleship , this isn't such a good maneuver .
    So read the instructions carefully . if they say this , IGNORE IT !  This goes for planes too .I had one kit that was a bear to build anyway and they had you put the cockpit and panels in AFTER you joined the fuselage halves . Don't try this , you won't like it !
    In Conclusion , I have to say , I think the writers of these have NEVER put one of the kits together at all , and certainly not the way it is written !    Tanker - Builder
    February 2014
Posted by CN Spots on Monday, March 23, 2015 1:09 PM
That's probably true.  Most of these instructions are probably created by graphic designers in an outside design firm with little to no interest in modeling.  They are most likely working from rough directions from the designers who created the kits.  As soon as they are done with that instruction manual they'll start on a cookbook cover.
I always build the thing in my head first, right down to paint and detailing, before I take the first piece off of the sprue.
Posted by Tojo72 on Monday, March 23, 2015 1:19 PM
Just about everyone realizes that Dragon instructions also need to be taken with a grain of salt also.
    November 2014
Posted by BLACKSMITHN on Monday, March 23, 2015 2:52 PM
Well, there's instructions and there's instructions. And some, as Cap'n Jack might say, they're really more like guidelines...
    February 2011
Posted by Raualduke on Tuesday, March 24, 2015 1:40 AM
I really think you should read the instructions front to back before beginning a  build, then just use common sense. Like tojo72 said, grain of salt
    September 2012
Posted by GMorrison on Tuesday, March 24, 2015 1:48 AM
Yeah, well try to build a building from the architectural plans.
In full disclosure, I am one.
For a mass consumption item like a hobby kit, yes a little more guidance is warranted.
But geez, I have built many a kit that came with an exploded single view.
I frankly don't think reading the instructions front to back does much good unless you already know what you are doing.
Better to dry fit stuff, and lay out the parts and play with them, IMO.
Posted by Don Stauffer on Tuesday, March 24, 2015 9:20 AM
I think we need to differentiate between plans, drawings and instructions.  I think modelers frequently tend to misuse these terms.
    August 2008
Posted by tankerbuilder on Tuesday, March 24, 2015 9:58 AM
Ah !
  Don , You are so correct on that . Plans I have all over the walls .Instructions in a file cabinet and drawings in two flat files .Whatta mess . But in summation you really have to know what your about to abandon instructions completely.
 Now the example with the Trumpy ship instructions was a really good example . Anyone who has been building at least past four ships knows the truth of that Mistake , right ?
    The one thing I do like in most , but , not all instructions is the parts map .My gosh, even " Metal Earth " gives you that for their product !       T.B.
    September 2012
Posted by GMorrison on Tuesday, March 24, 2015 10:03 AM
I like parts maps too.
The worst situation I can remember.
It was a Zvezda kit I think, maybe the Borodino.
No numbers on the sprues, so the parts map was critical.
PE set maybe had diagrams for the major stuff and a general discussion of which of the rest of the parts replaced which in the kit. So from PE to plastic parts map to sprue to model.
