Painting lines on external Fuel tanks.....
    June 2015
Posted by Mtdustbuster on Monday, June 22, 2015 8:35 PM
Guys, I'm having a terrible time trying to get straight lines on either external fuel tanks or say the aircraft nose, or any rounded and curved surface. any help or advice would be greatly appreciated. thanks!
Dustin
    February 2015
Posted by RRA2 on Tuesday, June 23, 2015 8:40 AM
Have you considered using colored automotive pin striping tape?  They come in wide ranges of color and sizes.
RA in AZ
    December 2011
Posted by Chrisk-k on Tuesday, June 23, 2015 11:29 AM
Use rubber rings on round or curved surfaces. There have been a few threads on that method. Search the forum.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    August 2013
Posted by Jay Jay on Tuesday, June 23, 2015 3:18 PM
Here's another tip from your Uncle Jay;
I do my bombs like this, I paint the whole thing the color of the stripe.  Then I cut a piece of masking tape the width of the stripe, stick it in place where i want the stripe, then repaint the whole thing OD or what ever color.  Take off the masking tape and voila, a painted stripe.,
    June 2013
Posted by RobGroot4 on Tuesday, June 23, 2015 8:35 PM
I have found dry transfers are pretty useful for this as they are somewhat flexible.
If you are set on painting (transfers can be a bit thick) try cutting 2 really thin strips of Tamiya tape for the very edges of your stripe (maybe 1-2mm wide).  Place those carefully, and then use small pieces of tape to do the surrounding areas.  Cutting the tape for the edges thin will let you tape it around the curves a little better.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
