solution for fixing the pigments or a better idea for weathering
    December 2013
Posted by Matt12 on Sunday, July 26, 2015 6:42 AM
Hello friends
i am building a hobbyboss 1/48 F-18 ,i want to make it look in service. after spraying the base color i pinwashed the model now i want to add some dark/light shades. i can either use my airbrush to lighten up the panels a bit or apply a matt coat followed by pastels pigments on top. what do you think? any other suggestions? Geeked
 on the other hand fixing the pigments is a problem itself, you can easily blew them away and make them disappear while spraying on top. is it gonna be ok if i lower the pressure to 10 psi or less? please let me know if you have a better idea, thanks. Yes
Posted by Don Stauffer on Sunday, July 26, 2015 11:21 AM
I prefer the airbrush route because I do not need to worry about fixing a powder.
    November 2008
Posted by plasticjunkie on Wednesday, July 29, 2015 7:35 AM
Matt
For such schemes I like to preshade in black then blend in the top coat from lighter center panels to darker borders. You can still do that to you model even with the decals. Just lighten the base coat with a couple of drops of white and shoot the center of the panels. You have to thin the paint down and dial down your PSI till it shoots right in your particular AB. Any overspray on the decals can be carefully removed with a small brush dampened (almost dry)  with thinner to carefully remove the fresh paint from the decals.
The trick is to do the shading very subtle. I just posted pictures of a 1/72 Tomcat done in this method.
cs.finescale.com/.../1836376.aspx
 GIFMaker.org_jy_Ayj_O
    December 2013
Posted by Matt12 on Saturday, August 1, 2015 2:18 PM
thanks , i checked your tomcat and noticed you had already sprayed on some of those decals as well, is that right?
    November 2008
Posted by plasticjunkie on Saturday, August 1, 2015 7:48 PM
No the decals went on after I did the fading but in your picture you just have a couple of decals on. I did a 1/48 Eduard FW190D-13 for the Butcher Bird GB a while back and had some silvering in my fuselage crosses. I dialed down to about 5-6 psi my Badger Renegade  and shot the mottling inside the crosses. What little over spray that got on the black field I removed with a fine brush dampened in thinner.
Here's a closeup of the cross (click on the picture twice) and as you can see there is no over spray
