Drying time of brushed on, odorless thinner reduced, OIL paints.
    August 2014
Posted by aWintersTale on Monday, August 31, 2015 5:14 PM
Inquiring if anyone used oil paints (the kind that come in a tube), diluted with odorless thinner and brushed on, and what the drying time was. I brushed on the same yesterday, and to my surprise, the paint rubbed off on my fingers today, showing only a slight drying. I thought it might be my el cheapo oil paint set, but I do realize that oils, especially diluted would seem to take longer to dry. I just didn't expect it to take this long. Thanks for your input.
    July 2004
Posted by stikpusher on Monday, August 31, 2015 5:30 PM
I have not used them beyond for washes, but in that case they usually take several hours to dry.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Monday, August 31, 2015 5:34 PM
Ditto, a couple of hours for washes. Oils do take a long long time. I tried doing what you describe to paint figures and just created a huge mess.
    December 2011
Posted by Chrisk-k on Monday, August 31, 2015 5:45 PM
Oils can take several months to dry.  I use oils for washes only (about thinned 95% with Mona Lisa Odorless Thinner) and they completely dry within 24-48 hours.  That's why I like oil washes.  I can always correct errors and fine-tune.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    August 2014
Posted by aWintersTale on Tuesday, September 1, 2015 12:40 AM
Thanks guys, for the response. As you all have indicated, oils as washes can show superior results, in the ability to hug a contour and just flow! Trying the oils thinned, as a brushable product on a figure showed a very smooth finish, but for the drying time. Waiting for it to dry is thumb-twiddling time. Its like watching paint dry Whistling.
    August 2005
Posted by Phil_H on Tuesday, September 1, 2015 1:21 AM
This is interesting reading. It seems different coloured pigments in the paint can also affect drying time.
http://www.winsornewton.com/na/discover/tips-and-techniques/oil-colour/understanding-the-drying-times-for-oil-colour-us
Posted by Don Stauffer on Tuesday, September 1, 2015 8:58 AM
I have never had a problem with washes made from model enamels flowing into recesses and crevices.
    December 2009
Posted by Tucohoward on Tuesday, September 1, 2015 9:06 AM
You can dry oil paints in minutes with a hair dryer. For anyone who has limited time or patience a hair dryer is an essential tool. Paint, washes, decals, all are done in minutes, not hours or days.
Jay
The Mighty Mo says no.
    August 2015
Posted by crown r n7 on Tuesday, September 1, 2015 11:30 AM
Over a glossy acrylic finish ? Don
 Nick.
    March 2010
Posted by Nathan T on Tuesday, September 1, 2015 11:54 AM
Oil paints made specifically for modeling, such as MIG oils, are the kind you want to use. They contain less linseed oil and just work better. Also, in chuck's mig thread he used an accelerator made for oils. Worth checking out.
    December 2011
Posted by Chrisk-k on Tuesday, September 1, 2015 8:43 PM
I swear by MIG oils because they contain little linseed oil.  I also use W&N oils and it's easy to extract linseed oil from them.  Just leave a small amount of W&N on a piece of cardboard for a few minutes.
Posted by Don Stauffer on Wednesday, September 2, 2015 9:16 AM
crown r n7
Nope, very seldom use glossy acrylic- I find it easier to get a good gloss finish with enamels.
    August 2015
Posted by crown r n7 on Wednesday, September 2, 2015 1:58 PM
and you use enamel washes.
 Nick.
    August 2014
Posted by aWintersTale on Tuesday, September 8, 2015 8:58 PM
I used to have a hair dryer when I had hair. Now I just shave my head, and consider it an extension of my face.  Confused
    May 2003
Posted by qmiester on Wednesday, September 9, 2015 7:58 AM
Back when I worked on figures, 90% of my work was done in oils. Basic rule I had was a minimum of 24 hrs of drying between coats.  This could be shortened when I built a "drying box". It was a small box w/holes in the top, a shelf where the figure was placed over a 60 to 75 watt light bulb.  It was lined w/ tinfoil and had a door. Put the figure in, close door and turn on the light.  Usually the figure was completely dry in 3 to 5 hrs.
Quincy
Posted by Don Stauffer on Wednesday, September 9, 2015 9:17 AM
While I do not use oils, I do primarily use enamels which also have a long drying time (especially gloss enamels).  I built a very similar drying box, and it has sure been well worth it.  I find a similar drying time with gloss enamels, and it has sure speeded up my work on models with slow drying finishes!
