Masking seam lines
    July 2015
Masking seam lines
Posted by Matt003 on Wednesday, September 30, 2015 10:51 PM
I've heared of people masking off seams and gaps before applying putty so as to preserve surface detail but I've never actually seen it in practice. Is there a reason for the lack in popularity for this technique?
Tags: Gap , masking , putty , Seam
    September 2012
Posted by GMorrison on Wednesday, September 30, 2015 11:35 PM
No.
If you don't you make more work for yourself. Also the two edges of tape help to sort of gage the level of putty.
    August 2013
Posted by Jay Jay on Thursday, October 1, 2015 7:24 AM
It's popular with me, I mask seams all the time. Smile
    March 2013
Posted by patrick206 on Friday, October 2, 2015 2:50 PM
I mask the seam lines simply to avoid any un-intentionally messy filler application, plus it prevents excessive removal of, or damage to, engraved panel lines. That results in preserving as much of the panel lines as possible, and less panel line length restoration prior to painting.
Once the filler has been applied and still soft, I place a drop of a compatible thinner on my gloved finger and wipe it along the side of the masking tape, spreading some of the filler back onto the tape. Immediately I pull the tape, then again wipe the filler edge, pulling the filler back inward toward the seam.
That makes for a much thinner edge of filler to sand away, but leaves the full amount of filler that was applied over the seam. I find it lessens the amount of time needed for seam filling and sanding, also preserving more of the surface details.
Patrick
Posted by waikong on Tuesday, October 13, 2015 10:45 PM
same here, I mask, not all the time. depending on the amount of fine lines near the seam.
