De bonder question
    July 2014
De bonder question
Posted by teejay on Thursday, December 3, 2015 8:05 PM
I accidentally drop some superglue on the surface of a model. I let it dry as I don't want to wipe it and cause more damage or smear. This is not a kit but a preassembled plastic truck that I was repairing so don't want to damage the color on the mold. What would you recommend to remove the glue. Is there something that can put to unglue it without damaging the plastic or melt the glue with out becoming tacky again?
Posted by Don Stauffer on Friday, December 4, 2015 9:58 AM
Yes, there is a product sold as CA Debonder.  I received my current bottle as a sample when I ordered some CA as part of a mail order.  I will certainly replace it as it approaches empty.
I have used it both for removing drops/gobs of CA inadvertently placed on surfaces, and to remove parts glued to model with CA when I found I had to remove them for various reasons.  Good stuff!
    May 2013
Posted by Greg on Friday, December 4, 2015 10:26 AM
And another use for the stuff......
The other day whilst repairing a houshold item with thin CA, I glued my thumb to the part. And I mean seriously.Could have easily been a trip to the ER.
The debonder and a little patience had the situation solved painlessly in short order.
It's a must have if there is CA in the house IMO.
    July 2014
Posted by teejay on Friday, December 4, 2015 11:38 PM
Thank you guys. Do you just drip it on the CA glue and let it soften or do you use cotton swab and keep wiping it on the glue till it melts? Any recommended brand I can use without damaging the plastic?
Posted by Don Stauffer on Saturday, December 5, 2015 10:19 AM
I put it on with the same method I put on the CA. If easily accessible I just put a drop on from the nozzle of the container. If it is less accessible I use a forked applicator that I use to put on the thin CA or accelerator.  For just removing from surface I then use the Q-tip.
    July 2014
Posted by teejay on Saturday, December 5, 2015 11:58 AM
Don Stauffer
Thanks Don. I was checking on google and there are lots of different brands. Any you would recommend or stay away from?
    May 2013
Posted by Greg on Saturday, December 5, 2015 12:06 PM
My personal preference for CA happens to be BSI Industries (Bob Smith). It's the stuff you see at your LHS branded for that store.
So I like to use their debonder too.....
http://www.bsi-inc.com/hardware/un_cure.html
    September 2012
Posted by GMorrison on Saturday, December 5, 2015 12:39 PM
Run a test first off model. Make a drip of the same CA on another piece, or even on the bottom of the truck where you won't have to see the results (better yet), then try your de-bonder and figure out what works best. Start with just a little de-bonder at a time.
Like greg said, always have a bottle within reach.
One reason why I've started to get away from using it as much as I used to.
    January 2016
Posted by ichiban on Wednesday, January 27, 2016 7:24 PM
Acetone is as good as the hoo by deboned ts and MUCH cheaper
