One trick that works in some areas, and is simple, is to make panel line decals. Using inkjet decal techniques, make a very fine line, one or two pixels wide, in black, dark gray, or a darkened tint of the color used on the surface. It makes quite subtle panel lines. You can also put little rivet dots along the line (these should NOT be black, but a darkened version of the main color used).
