What grit sandpaper for sanding Squandron green putty ?
    December 2015
Posted by Dash8 on Saturday, December 19, 2015 10:10 PM
I am using it on airplane seams and gaps. I have 800
grit wet sandpaper is that fine enough ? I don't want
the sanding scratches to show through the primer
coat. I take it sanding is done dry ?
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
Posted by Don Stauffer on Sunday, December 20, 2015 1:04 PM
I consider 800 a bit too fine.  I generally use two grades- 320 or 400 for initial smoothing and shaping, then 600 or 800 for removing the scratches. I find using just the fine grade takes too long, and it isn't that much of an effort just to switch grades at the proper point.
    December 2015
Posted by Dash8 on Sunday, December 20, 2015 10:22 PM
Thanks Don !
Ontario, CANADA
    August 2005
Posted by EdGrune on Monday, December 21, 2015 8:21 AM
I knock the majority of the putty down with a Sally Beauty Supply fine nail stick, then go back over with an extra fine nail stick to complete the sanding.  These can be used wet. Then finish up with a nail buffer which has hardly any grit at all.   Polishes and removes any remaining scratches.
These nail sticks have a plastic core with foam backing.  They can be scored with an Xacto knife and snapped off to be cut/shaped as needed to fit into fine spaces
I will lay a couple of strips of masking tape along the seam to be filled, leaving a 1/8-inch or finer gap between them.    Fill the seam with putty, smooth,  and allow to dry.  Once dry, I sand with the fine stick before removing the tape.   The tape protects the surrounding detail.   Progress to the x-fine grit and sand out any scratches.   Pull the tape - there may be some ridges along the edges.   Sand them down with the x-fine stick.  Then polish with the buffer stick
    December 2015
Posted by Dash8 on Tuesday, December 22, 2015 9:09 PM
EdGrune
Cool thanks for the info!
Ontario, CANADA
Posted by Don Stauffer on Wednesday, December 23, 2015 9:22 AM
I have a couple of sets of needle files- a regular sized set and a small micro set. I find these great for the initial smoothing of putty and seams. I just finish up with fine sandpaper but the files take it down to that point very quickly and accurately.  Putty does clog the files periodically but I bought a brass wire brush and it cleans them fairly easily.
    December 2015
Posted by Dash8 on Wednesday, January 6, 2016 1:10 PM
Thanks eveyone ! I have been using 320 garnet
and 1000 silcon carbide for that putty, so far
so good. The sanding scratches do not show
through the pimer coat that I can tell.
Ontario, CANADA
