Dioramas, back to the basics. HELP!
    January 2016
Posted by Mrkilroy96 on Thursday, January 28, 2016 2:01 PM
Hey guys, I'm new to the forums but I'm a 19 year old modeler who has been building seriously for about 5 years (I started when I was 6 but didn't get good until years later) and I am fed up with my cruddy grasswork. I would love some tips for getting a good technique in terms or just a plain grass over dirt diorama building. I usually use tile grout, airbrush it with a myriad of earth colors, varying from tamiya brown, hull red, dark yellow and khaki and then finish it up with some pigments. This generally isn't my issue, it is the grass to put on top of it. . . I use woodland scenic static grass and I puff it out on top but it always just ends up looking like floppy green hair dumped on some dirt and I'm tired of it. Any  suggestions for a more realistic grass option or if I'm just doing it wrong? Thanks guys
Posted by Don Stauffer on Friday, January 29, 2016 9:12 AM
Try the woodlands grass putting it on more sparsely.
For a flat and level grass, model railroad area of hobby shops has sheets of grass that look pretty good.  One version looks like a golf green, and not to good for most dioramas, but they also sell a mottled more wild turf look.  You coat back with white glue and apply to base.
Posted by Bish on Friday, January 29, 2016 1:55 PM
I use Woodlands grass and a few other brands. How are you applying it. I mix up a range of colours and types with differant lengths and put it on you a puffer bottle sold by Noch.
Heres a couple of example of the results i get.
    October 2008
Posted by P mitch on Friday, January 29, 2016 4:04 PM
I know its lazy but you can get grass mats which look good and are a whole let less work
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    January 2016
Posted by Mrkilroy96 on Saturday, January 30, 2016 1:08 AM
Thanks guys for all the help. I think I have just been putting too much on so you can't really see the dirt. I'm also gonna try color variation in the grass with some yellows and Browns so it's not just solid green. Appreciate all the help!
Posted by Don Stauffer on Saturday, January 30, 2016 9:51 AM
One trick if you want weeds in your grass is to use fine stranded electrical wire- hookup wire.  Cut pieces about 3/4 inch long, strip insulation from half of it.  Unwind the strands a bit.  Drill hole in base about the size of the insulated portion and glue insulated end in base.  Paint the copper wire tan, brown, or OD- or a mix of those.
    January 2006
Posted by dirkpitt77 on Saturday, January 30, 2016 7:46 PM
I have to say, I haven't found a way to make decent looking grass that ISN'T tedious. It'll take me two or three weeks to put down a simple layer of green adhered by white glue, and then adding weeds and other scrub over time. And it still looks...mediocre. I think foliage is one of the most challenging aspects of modeling. Harder even than nmf finishes.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
