Liquid mask
    August 2012
Liquid mask
Posted by JMorgan on Wednesday, February 24, 2016 11:22 AM
Is this stuff designed to work over plastic only? I used it over flat paint and found it very hard to peel off.
Posted by wjbwjb29 on Wednesday, February 24, 2016 2:27 PM
The stuff can be a bear to get off. You have to put it on thick if you can.soapy water will loosen it up. I used it on the decks of some 1/7oo ships boats and had to soak them to get it off which was not a problem.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    April 2009
Posted by Cadet Chuck on Wednesday, February 24, 2016 5:55 PM
I have had nothing but disasters using liquid masks of several brands.  I just don't use it anymore.
    June 2010
Posted by 5-high on Wednesday, February 24, 2016 5:56 PM
Yes ..the trick is to apply it thick enough so you can peel it off ..too thin and yea ..it's a bear too remove. And I have used it on flat paints too ...no issues as long as it's thick enough. .great stuff
5-high
    September 2013
Posted by Marcus McBean on Wednesday, February 24, 2016 8:27 PM
I only use it on small areas and put it on thick or it will be a pain to remove.
