Recreating bullet holes and ricochets on armor
    November 2013
Posted by TheMotherLand on Wednesday, March 30, 2016 9:03 AM
Hey everyone!  Trying to add some battle damage to my models.  I was wondering what the best way to recreate bullet holes and ricochets on armor would be along with the proper colors to paint them?  Any tips or advice would be appreciated!
Tags: armor , painting
Posted by Texgunner on Wednesday, March 30, 2016 9:20 AM
I'll tell you how I do it.  I first thin the plastic down to scale thickness, from the inside, with a motor-tool.  When I can just about see through the plastic when held up to a light, I use a sharpened needle to poke a hole through where I want the bullet to "hit".  Then, if applicable, I push the needle through the "out" side and with a little experimenting, you should be able to duplicate the spread out look of the "exit" wound.   Experiment on some scrap plastic and soon you'll have it down pat!  Good luck!
Gary
"All you mugs need to get busy building, and post pics!"
Posted by Tojo72 on Wednesday, March 30, 2016 11:22 AM
Just be careful,your not going to have bullet holes on tanks unless your talking shurzen or exhaust shields,ricochets,and dings yes but no bullet holes.
    September 2012
Posted by GMorrison on Wednesday, March 30, 2016 11:39 AM
I suggest you always work from photos. I've seen for instance where a 20mm round put a hole in an aircraft a basketball would fit through. What we think we know and what is, often don't much overlap.
Posted by Texgunner on Wednesday, March 30, 2016 11:51 AM
Tojo72
This is true.  I've only put bullet holes in armor storage bins, bustles, etc.  A grinding burr in a motor tool will produce some nice battle dings in armor.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, March 30, 2016 12:55 PM
An old, old, trick I did back in the 70s was heat a nail under flame and poke into the fuselage or whatnot.
    November 2013
Posted by TheMotherLand on Wednesday, March 30, 2016 2:40 PM
Honestly I didn't even think about where the bullet holes would and wouldn't be!  Great advice and help guys...I really appreciate it!
    January 2013
Posted by jibber on Thursday, March 31, 2016 1:12 PM
One of my "go to" techniques for damage from rounds is the use of an awl. I keep a candle near my bench for heating sprue but also for slightly heating the end of an awl. Take the heated awl tip and press it where you want the round to be and hold it a split second. when you pull it out you'll get a small ridge around the opening that simulates real hits. To make it even more real, slightly dry brush inside the hole with a shiny steel, very lightly at forst until you get it just right. Its very easy and you can experiment on scrap, also try laying the awl on an agle with the same process. It gives a glancing blow look. I'll see if I have a photo or two.
Heres a couple of pics of battle damage using an awl, hobby knife and weathering products. Pretty simple really.
Good luck, maybe something here will help.
Terry
    January 2013
Posted by jibber on Thursday, March 31, 2016 1:24 PM
    July 2004
Posted by stikpusher on Thursday, March 31, 2016 2:51 PM
In most cases, a motor tool/Dremel tool is your best bet for making the damage. Fenders and stowage bins are made from various gauges of sheet metal and can be pierced by small arms fire and artillery shrapnel. Armor plate will just get dinged up. Weapons that pierce armor, HEAT (Hollow Charge), Sabot, AP Cap, etc. have varying characteristics about the type of damage they inflict when piercing the armor. Oh yes, as in a photo above, machine guns do not make impacts in a neat little line 99.9% of the time. Often the taget is moving, the gun platform moving, and the gun itself from the firing, so they impact in a random splash pattern on the target. At longer ranges, the bullets can be tumbling, or from worn out barrels.
Here is a target tank with the various types of rounds used: Armor Piercing Discarding Sabot, Armor Piercing Fin Stabilized Discarding Sabot, High Explosive Anti Tank (note the surrounding blast effect scaring compared to the others), High Explosive Plastic
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2014
Posted by Tanker - Builder on Friday, April 1, 2016 7:07 AM
Ah !
 You have hit on something there "G". I have seen pictures of planes with holes big enough to almost crawl through .The biggest I've seen on a tank was at a Museum and it was the size of a basketball ( Approximate ) in the Schurzen .  T.B.
