photoetched metals
    January 2009
photoetched metals
Posted by recce009 on Thursday, August 4, 2016 6:56 AM
any tips for a first time user of photoetched metals? thanks
    September 2014
Posted by rooster513 on Thursday, August 4, 2016 7:19 AM
I've only used PE a couple times so I'll just share my limited knowledge. Have a nice sharp hobby knife or razor blade on hand to cut pieces from the fret. I've seen some suggest placing the fret on the sticky side of a piece of tape so the parts don't go flying when you cut them off. Magnification of some kind is very helpful for small assemblies. Next, make sure to double or triple check which way the piece needs to be bent BEFORE bending it or there is a good chance it will break when trying to bend it back (wonder how I know thisWhistling. Lastly, use a glue that will give you some working time for parts that you need to position. I used regular super glue on my last build and it's a pain trying to get it in position before the glue sets up, which is about 3 seconds later LOL. I just recieved a bottle of Gator's Grip glue so I'm looking forward to giving that a try on my next build.
Others on here have a lot more experience then me and should be able to give some more advice.
Jus take your time and you'll do fineBig Smile
-Andy
Posted by Tojo72 on Thursday, August 4, 2016 7:37 AM
Gator Grip Glue is the way to go,just discovered it for my last two builds.Great stuff.
Posted by Don Stauffer on Thursday, August 4, 2016 9:26 AM
Because PE pieces are so very light, they do not need a lot of bonding strength to hold in place.  Many of us use white glue, diluted 1:1 with water.  Gives you a lot of working time, excess glue does not make as much of a mess.
Carrying and placing a piece at the right spot on model can require some skill. Use of tweezers can launch a piece across the room of your fingers twich.  Some use those little vacuum picker-uppers, but there is a limit to how small of a piece they will hold.  I sometimes use a tiny ball of  poster tack on end of a toothpick, but it takes two hands- one to hold toothpick and another to hold some pointed instrument to hold the PE in place while you pull away the toothpick and tack.
Posted by Bish on Thursday, August 4, 2016 10:45 AM
Check the set and determine which bits you don't need. Some PE parts, such as flat brake lines, are less than realistic.
    July 2013
Posted by steve5 on Thursday, August 4, 2016 2:48 PM
    August 2014
Posted by goldhammer on Friday, August 5, 2016 9:34 AM
I picked up a set of small pliers at Hobby Lobby.  Several diferent types in the set, especially the smooth jawed flat nose.  Usefull for bending PE.  In the jewelery making section, under $15
    May 2013
Posted by Greg on Friday, August 5, 2016 10:05 AM
Good ideas and advice above.
Also, if you do some Googling, there are quite a few very good video tutes out there. When I started with PE  a few years back, I didn't even know what a PE was or what a fret looked like, let alone what to do with it. That's what I did.
In addition to Tojo's Gator Grip recommendation, their new thin formula is the treat for PE, even better than the orig I think. I gave up with CA and PE even though lots of folks use it. I just make messes.
    January 2009
Posted by recce009 on Tuesday, August 9, 2016 2:08 PM
Thanks to all who replied. Smile
    September 2012
Posted by GMorrison on Tuesday, August 9, 2016 3:40 PM
If you are installing ship railing, try not to have the joins at the corners.
    July 2013
Posted by steve5 on Wednesday, August 10, 2016 12:35 AM
is that for strength gmorrison
    September 2013
Posted by Marcus McBean on Thursday, August 11, 2016 7:58 PM
Its harder to line up the rails and a bend at the corners look better, I think.
Posted by Don Stauffer on Friday, August 12, 2016 9:21 AM
Marcus McBean
I agree.  And, bend those corners, fitting to deck planform, before starting attachment.  Things go much quicker and smoother if you are not trying to bend as you glue.
