Three finger acrobatics
Posted by Don Stauffer on Saturday, September 10, 2016 9:26 AM
I often have trouble applying CA accelerator to a model when I have to hold the model in my left hand.  Ships and seaplanes, in particular, or hard to set down on a benchtop at many points during their building, so I have to hold it in hand.  I use CA gel, which has much longer set times than the thin stuff, so I use the accelerator, using a fork tool I built.  But with left hand holding model, right hand holding the tool, I had no hand left to push down the spray cap on the accelerator bottle.  I have now acquired a three-finger technique- hold tool in thumb and index finger, push spray cap down with middle finger!  I seem to have it down okay, now, and can do it regularly.
Posted by Texgunner on Saturday, September 10, 2016 9:30 AM
That's a good idea Don.  Myself, I keep a small amount of accelerator in one of those little square Testors bottles, and then use a small brush to apply.
"All you mugs need to get busy building, and post pics!"
    August 2013
Posted by Jay Jay on Saturday, September 10, 2016 11:31 AM
I put my accelerator in a dropper bottle like the kind Velajo paint comes in. I just put a drop of acc. right from the botlle onto my ca'd part.  easy
Posted by Texgunner on Saturday, September 10, 2016 11:57 AM
Jay Jay
Oh, I like that idea too!  Thanks Jay, I'm using that one.
Gary
    March 2014
Posted by BarrettDuke on Sunday, September 11, 2016 5:07 AM
Don. Thanks for the tip. I agree that is one of the most frustrating parts of modeling. The problem I run into with that technique is that it takes so much pressure to push down the plunger that I have often had the accelerator bottle shoot out from under my finger instead of spray some accelerator. I wish I could find a roll of tape or something with the right size center opening that I can sit the bottle into to help keep it stable. Any suggestions for that? Barrett
Posted by Texgunner on Sunday, September 11, 2016 8:15 AM
I have a piece of very thin plywood on my workbench, maybe 10"x12", with several different sized "cut-outs" in it.  They are sized for different size round and square bottles.  The square holes have a low "fence" on all four sides that forms a wall of shorts that holds the bottle in place.  You can see a bit of what I'm describing in this pic.  The 35mm film can holding stir sticks is in a round cut-out.
Posted by Don Stauffer on Sunday, September 11, 2016 11:23 AM
The reason I don't pour it out into something is how fast it evaporates- at least the brand I use.  I used to spray it on the fork before I picked up the model, but that stuff is gone in less than a minute, and sometimes I was not picking the model up and positioning it soon enough- the stuff would be gone already.
    June 2014
Posted by Tanker - Builder on Wednesday, December 7, 2016 9:47 AM
Don;
Hi, what I do is this . You know the spare bottles for airbrushes ? Well I put the accelerator in one of those .Then when I need some I use a " Q " tip to apply it a small distance from the glued joint  .
   This way I don't have to worry about getting it on the joint . Just get the " Q " tip close and press . That squeezes out just enough to drip on the CA , setting it . As far as evaporation of the ACC. I have noticed only a minimal amount .  T.B.
