Sanding and polishing a canopy
    August 2016
Posted by PaulieF on Saturday, September 17, 2016 1:15 PM
I searched the forums and couldnt find the answer to this but if its on here somewhere and I duplicated a post, I apologize.
I just sanded my B-25J Mitchell Cockpit canopy with 1000 grit sand paper to remove all the raised detail. I got that all taken care of but now I want to polish it and get it clear.  I put rubbing compound on it and hit it with the polishing wheel in my mini drill press but its not working. I saw a video on youtube where the person does this and it seems to work..Do you guys have a better option or tell me the correct thing to do? Thanks!!
I've been known to kiss a fish or two, with a little bit of tongue. Don't judge me.
On the bench: Hasegawa BF109E
In the hanger: 1/48 Tamiya De Havilland Mosquito
In the trash: Revell 1/48 B-25J Mitchell
    November 2003
Posted by mississippivol on Saturday, September 17, 2016 2:23 PM
One way to clear it up is with a polish kit containing paper grits from 3200 to 10,000 grit. Start with the 3200 and proceed with the next higher number until you finish up with the 10k grit. Then you should be able to use a liquid polish like Novus to get the final shine, or dip it in Future floor polish, which is what I do.
    August 2016
Posted by PaulieF on Saturday, September 17, 2016 8:08 PM
mississippivol
Ugh.. lol.. I just want it be clear right now. I cant wait to get all that stuff! HAHAHA!
    November 2003
Posted by mississippivol on Saturday, September 17, 2016 9:21 PM
I hear ya! You could go for the Future dip immediately. Might get you closer to right.
    August 2016
Posted by PaulieF on Saturday, September 17, 2016 9:29 PM
Its already all sanded and very scratched up. I didnt want all that raised detail on there. I just want to make my own lines. Ive tried everything to polish this thing but nothing works. I even used Flitz on a buffing wheel.   Thank God, this kit came with an extra canopy.  I was just testing the first one out. I cracked the hell out of it too.
    November 2008
Posted by mrmike on Saturday, September 17, 2016 10:59 PM
If you have a store in your area that sells Automotive paints and supplies, they will have much finer grades of wet & dry sandpaper, foam sanding pads and other fine finishing products that will help you buff out your canopy(ies) to a good lustre before the Future dip.
    August 2016
Posted by PaulieF on Sunday, September 18, 2016 4:48 AM
mrmike
Thanks Mike... Theres a napa auto parts near my house.. they should have some of that stuff..
    February 2006
Posted by Wilbur Wright on Sunday, September 18, 2016 11:12 AM
I get all my extremely fine sandpaper from the autobody store.  It's relatively inexpensive and they have the best quality wet sand paper.  Always wet sand canopies, and by hand.  Personally I carefully and slowly scrape off the seam with an x-acto #11, then 320 to 2000 wet sand,  then Future.
Posted by Don Stauffer on Sunday, September 18, 2016 11:33 AM
I recommend the Future route. If I have flaws a canopy or windshield, I only go down to #600.  The future takes it from there.
    June 2014
Posted by Tanker - Builder on Wednesday, September 21, 2016 1:52 PM
Hi;
 I am sure my approach is totally different . I sand the Canopy inside and out with 3200 grit wet and sloppy .then I get jewelry polish or headlight cover polish .The second by KIT in an auto parts store .
  Then the fun . A big glob of polish and a " Q ' tip with added cotton and just scrub away on the inside till it gets shiny and mark free .Then Tooth paste for the finish on the outside . You don't really need that Future stuff . Use the Novus system # 2 polish and finisher .
    The biggest thing is to never put the canopy in a strain  , like squeezing or flattening .Be very careful and let it float around in the palm of your hand if you think you might hurt it .      T.B.
    August 2016
Posted by PaulieF on Wednesday, September 21, 2016 7:25 PM
Tanker - Builder
Hi;
I got it down perfectly now. THis canopy is 100 percent perfectly clear. I did it similar to what you are doing. I started out with 1000 wet sand and worked my way to 2000 grit. THen I used the headlight polish called PlastX. I also did a light buffing of white diamond buffing stick. I was pretty close to done then but I did dip it in future and that was just the icing on the cake! Thanks for all the advice. Its much appreciated!
    August 2016
Posted by PaulieF on Thursday, September 22, 2016 4:34 AM
of course I put a deep gouge in the canopy masking it and I cant get that sucker out no matter what. ugh.
    November 2008
Posted by plasticjunkie on Thursday, September 22, 2016 7:39 AM
I use nail sanding/polishing sticks from Target or Walmart. There's like 8 different grits on the stick, ranging from sanding to polishing. I then take a Q Tip and a dab of Siminiz Haze Remover and polish the inside and outside of the canopy. then I use an old soft cotton T shirt to clean everything and dip the canopy in Future which also protects the canopy against fogging and inproves the clarity. Aqua Gloss from Alclad will also work just like Future.
 GIFMaker.org_jy_Ayj_O
    June 2014
Posted by Tanker - Builder on Thursday, September 22, 2016 9:58 AM
 Hi;
 I am glad it worked out
On your aircraft it's important .Gotta see the goodies in the office , right ? T.B.
    June 2014
Posted by Tanker - Builder on Thursday, September 22, 2016 10:02 AM
PaulieF;
   This is perfect ! Have you seen the new glue advertised on T.V. You know apply a little and hit it with the U.V.light . Well it works perfect for this kind of repair AND you can sand it if you have to.
   Now the trick is to make as thin an application as possible .The nice part .If you don't like it at first , wipe it off BEFORE you hit it with the light and do it over !
 Try it , You'll like it !    T.B.
    August 2016
Posted by PaulieF on Thursday, September 22, 2016 10:53 AM
Tanker - Builder
PaulieF;
I have some UV epoxy that I use for fly tying. I dont think its glue  as much as it is epoxy. Is that what youre talking about? It comes in thin and thick. I have it in the thin version..
    June 2016
Posted by TxAggie05 on Tuesday, September 27, 2016 10:30 PM
ive had great success with the tamiya polishing compounds. Make the canopies crystal clear.
