Weathering 1989 Batwing
    August 2016
Posted by Dfsoutherland on Tuesday, September 27, 2016 8:05 PM
 Hello Fellow Builders -
I'm currently building a 1989 Batwing (my favourite Bat vehicle of all time every since I was a kid). I've attached a link of a reference I'm using and I have no idea how to acheive that beautiful white-ish gradient weathering on the panels.
If someone could school me or at least tell me what the technique is called, I'd be very thankful.
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=&url=http%3A%2F%2Fdarksidetoy.com%2FBatwing-Prop-Replica-by-Hollywood-Collectors-Gallery-and-Toynami&psig=AFQjCNGzETkGc80gvm1VCtUIoPnQszrulQ&ust=1475109826325176
    October 2010
Posted by hypertex on Thursday, September 29, 2016 7:04 AM
First, here is a working link.
http://darksidetoy.com/Batwing-Prop-Replica-by-Hollywood-Collectors-Gallery-and-Toynami
The fading/blending effect can be done with an airbrush. Each panel can be masked off and the lighter color faded in with the airbrush at an angle to the surface. Do a search for "airbrush fading" or "airbrush blending."
    August 2016
Posted by Dfsoutherland on Thursday, September 29, 2016 4:48 PM
Will do - thanks
    August 2009
Posted by robiwon on Friday, October 14, 2016 8:09 AM
You can also do it with pastel chalks if you don't have an airbrush. Lay a piece of tape on the panle line. Take a white, light grey, ect. stick and scrape with your knife to make a powder. Take a short flat brush and brush the powder from the tape back onto the exposed panel. Peel the tape off and you will have the effect your looking for. Seal the powder with a semi gloss topcoat.
You can see the same effect I applied to this Cylon Raider on some of the panels.
