StyreneSandwich
StyreneSandwich
Posted by Anonymous on Saturday, March 20, 2004 5:56 PM
I just bought a Hasegawa Skyhawk and was thinking about how to do the control panel. There is a decal the your saposed to put over the control panel. i was thinking that I could drill out the spot for the dials and then out the decal on a piece of sheet styrene. then I would glue this to the pack of the control panel. Has this been done before? Can this work?
Thanks
    March 2004
Posted by uilleann on Saturday, March 20, 2004 6:58 PM
I did a similar thing (but kinda reversed) on my Tamiya F-117 a while back. I actually built up the radar screens to stand out a little bit from the rest of the model. I used many of the same techniques you describe here (at least I think I did what you're describing!) I see no reason why it wouldn't be possible. The one thing I can think of to watch out for is that you'll need to thin the panel quite a bit for it to appear to scale. With the thickness taken down so far, it might be pretty easy to damage the panel beyond repair.
Have you got any options of adding PE details or perhaps scratch building some bezels from cut up old ink tubes of ball point pens?
You can find a bit of info on the panel I did for the F-117 here (towards the end of the thread I think):
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=16899
Photos have been posted towards the top, and then the description and build technique for the panel is found further down.
Brian~
"I may not fly with the eagles.....but weasels don't get sucked into jet engines!"
