Screw-driver Lathe?
Screw-driver Lathe?
Posted by Anonymous on Sunday, March 28, 2004 4:50 PM
Hello everyone. I can't afford a lathe, so I decided to make one. I took an elecrtic screwdriver and taped it to the table. Instead of puting a drill bit in, I put in the part and hold down the button. I'm waiting for the battery to charge, so I havn't tried it, but how do you think it will work?
Posted by Torio on Sunday, March 28, 2004 7:22 PM
I fear it will be much too slow; I would consider a Dremel or whatever brand you prefer, instead of this set.
Thank you all for coming José
Posted by Anonymous on Monday, March 29, 2004 11:37 AM
i took a black & decker rechargable screw driver and bought a conversion chuck that allows the use of standard drill bits & this allow be to be able to do tapers or some drilling, polishing & turning. on wood or styrene rods etc.
    January 2003
Posted by Hoser on Monday, March 29, 2004 1:26 PM
Following is a link on how to turn your Dremel into a lathe. Its from a ship modeling site and deals with turning wood. You can probably turn plastic easily, but I doubt if a Dremel has enough tourque to turn aluminum. Anyway, here you go -
http://www.naut-res-guild.org/services/shopnotes/mini-lathe/min-lath.html
"Trust no one; even those people you know and trust." - Jack S. Margolis
Posted by Anonymous on Monday, March 29, 2004 4:22 PM
Yeah, um it kind of is too slow like Jos'e predictedDisapprove [V]. Thanks everyone, but I'll find another way with or without a dremel (my Dad said "don't you dare use a dremel as a lathe"), so it's kind of off. Thanks though
Posted by MikeV on Monday, March 29, 2004 7:51 PM
How about a cordless drill/driver?
I have a Craftsman 1/2" 19.2V that would spin anything at a good speed, although it is pretty big and bulky to get set up as a lathe, unless you put it in a vice or something.
    January 2004
Posted by MusicCity on Monday, March 29, 2004 9:31 PM
Well, what you could do is get a Dremel drill press conversion. Basically it's just a jig that holds the Dremel and allows it to be used as a drill press. Since the Dremel is held solidly your dad couldn't complain too much Wink [;)]
They used to be pretty inexpensive, but I haven't priced them in a lot of years.
