Removing molded on ladders etc.
    January 2015
Posted by Jahno on Tuesday, December 19, 2017 11:51 AM
Hey everyone! This my first post and would appreciate some help. I'm on my first foray into photoetch. I'm building Tamiya's 1/350 Fletcher. I'm looking for a methodology for removing the molded on ladders etc. File first? Just use sandpaper? Don't want to screw up the finish so you can tell it's been worked on. What do you guys think?
    August 2013
Posted by Jay Jay on Friday, December 22, 2017 10:25 AM
Removing molded detail is mainly a process. i first try to clip of as much as I can with my Xuron sprue cutter. If there is a lot of the detail still left I'll CAREFULLY grind it off with a Dremel tool on the lowest setting. Then  you can tape around the area to protect the surface while sanding what remains with sucessively finer sandpaper until the area is smooth. Good files can save a lot of work here instead of sandpaper if you have them. If ,after all of that ,the area is not smooth enough, it can be polished with Novus #2 plastic polish back to the original sheen of the plastic. Good luck
    January 2015
Posted by Jahno on Friday, December 22, 2017 11:11 AM
Thank you for your response!
    April 2005
Posted by ddp59 on Friday, December 22, 2017 11:36 AM
i would use a chisel blade to cleanup after removing the molded on ladders.
    August 2005
Posted by EdGrune on Friday, December 22, 2017 11:48 AM
Jay Jay
A dissenting opinion -
Using a Dremel, even at its slowest speed is among the fastest means of screwing-up the surface.   Melting is almost a given.  Motorized tools are good mostly when hogging off large things like resin pour stubs
Very difficult to get close enough with a set of side clippers/sprue cutters.
Use a #17 Xacto chisel.   Hold the blade flat against the surface (bevel up) and gently pare away the raised surface.  Go back with set of sanding sticks and clean up using coarser to finer grits.   Sometimes old-school is faster & better
    March 2013
Posted by patrick206 on Friday, December 22, 2017 3:30 PM
From Micro Mark I bought a detail removal chisel, quite good at getting rid of unwanted plastic lines and rivets. I think about $10. Look it up on line, it works really well for me.
Whether an X-acto chisel or other, I find slightly rounding the side corners at the sharp end to be important, otherwise it's easy to gouge the plastic as it moves over the surface. Overall I lose less adjoining details around the area I'm working on, with no surface tool damage to correct.
Patrick
    January 2015
Posted by Jahno on Friday, December 22, 2017 6:47 PM
Thank you!
    August 2013
Posted by Jay Jay on Saturday, December 23, 2017 9:29 AM
you are so right Ed. i didn't consider the very tiny detail on a 1/350 scale model in which case the Dremel and sprue cutters wouldn't be good tools to use ...my bad
Posted by Don Stauffer on Saturday, December 23, 2017 10:07 AM
ddp59
I have a really nice, sharp 1/4 inch chisel (Stanley) that does a nice job of removing ladders all by itself.  If I am careful, virtually no cleanup needed.  If you are going to replace them with PE ladders, removal need not be perfect if any slight damages or unevenless is restricted to area behind ladder- not very visible through new PE ladder.
I usually grasp the chisel on the blade, not far from edge, rather than the handle.  The chisel is sharp enough it does not take much force.  I try to take off a first cut leaving a few mil of the ladder, then I do a more careful second cut flush with the bulkhead.
    January 2014
Posted by Silver on Monday, January 8, 2018 4:09 PM
Use a thin micro flat file several  times then with Tamils liquid thin cement brush over several times until it levels out.
    November 2008
Posted by plasticjunkie on Saturday, January 27, 2018 7:27 AM
EdGrune
Ditto Same method I use.
 GIFMaker.org_jy_Ayj_O
    September 2012
Posted by GMorrison on Saturday, January 27, 2018 1:29 PM
Often too a little trial fitting will reveal that something like a water tight door or a ladder doesn’t need to be entirely removed if you are putting a new one over the spot. The more the better, but it might not have to be pristine.
Remember “Aztec” ladders?
