Deluxe Perfect Putty Drying Time?
    April 2018
Posted by Oxboy on Thursday, April 26, 2018 2:37 PM
Hi guys,
How long do you wait after applying this putty to seams before hitting it with the damp Q-Tip?
Also do you thin it with anything before application or use as is out of the tube?
Thanks.
    May 2013
Posted by hogfanfs on Thursday, April 26, 2018 2:47 PM
I use it as is out of the tube. As for drying, it depends. For right angle seams, I‘ve hit it right away with a wet q-tip. Then, I have let it dry over night when I wanted to remove less of the putty. Hope this helps.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
