In addition to the Bondo red solvent based putty, there is Bondo Professional Glazing & Spot putty. Bondo red is essentially the same as Dr Microtools filler putty. These solvent putties take hours for the solvent to evaporate and harden.
Bondo Pro is a 2 part putty. Mix a quarter-size dab of putty with a pea-size spot of hardener and apply. Work in small areas and quickly. It hardens in a few minutes allowing you to sand and continue work without the overnight wait for the solvent outty to dry. This putty sands and feathers well.
