Keeping sharp corners when sanding
dlh
    March 2017
Posted by dlh on Sunday, August 19, 2018 10:06 AM
I can't seem to keep the sharp edges when removing ejector pin marks and seams. Commercial sanding sticks use foam as a backing so that doesn't work very well.  I'm gluing sandpaper to wood blocks (might try metal bar stock), but still am having trouble keeping the block perfectly parallel or at right angles to the work.  It seems that the smaller the piece, the harder it is. Maybe this just needs a certain technique, or practice.  I'm remembering the nice sharp edges achieved with a belt or disk sander in woodworking.
Anyone have advice or a technique that works for you?
Thanks,
Dave
    January 2006
Posted by Paul Budzik on Sunday, August 19, 2018 10:29 AM
See if this helps ...
Paul
Paul
dlh
    March 2017
Posted by dlh on Sunday, August 19, 2018 10:37 AM
Paul Budzik
Paul
Thanks. Excellent advice. The direction of sanding was most helpful.  I thought I might try afixing sandpaper to the inside of a piece of aluminum angle and using that to keep the part at right angles.  Anyway, there is much good advice in that video.  I learned a lot.
Thanks,
Dave
    June 2014
Posted by Tanker - Builder on Sunday, August 19, 2018 11:08 AM
Dave;
 What I do if the divots and parting pin marks are on a flat piece is this . I put it in a jig made of the same thickness of Evergreen plastic .Then when I sand it is all flat  ,with no chance of rolling over an edge .
 Been doing it this way for years . I also use the adjustable pencil sized sander . This primarily for tight spots . Also if the pin marks are too deep you can use a craft punch and punch out a disc out of thin ( .010 ) and insert it in the hole and sand it to match the surface .
dlh
    March 2017
Posted by dlh on Sunday, August 19, 2018 12:33 PM
Tanker - Builder
Dave;
Very good thinking.  I was thinking of a jig but didn't consider allowing the jig to be sanded with the piece.
Thanks,
Dave
    September 2012
Posted by GMorrison on Monday, August 20, 2018 1:22 AM
I mask with tape right down onto the area, within 0.10 inches, of the ares to be sanded.
dlh
    March 2017
Posted by dlh on Monday, August 20, 2018 11:13 AM
dlh
Paul Budzik
Paul
Thanks,
Dave
This video proved to be extremely helpful. Thanks. Taping the sandpaper to an acrylic block and sanding in one direction only, improved results dramatically.
(There was some cussing trying to cut acrylicSuper Angry)
