Advice - removing surface detail for photo etch
dlh
    March 2017
Posted by dlh on Tuesday, October 9, 2018 10:48 AM
I have a Tamiya Mercedes SLR McLaren and photo etch detail.
https://www.tamiyausa.com/shop/124-sports-car-series/mercedes-benz-slr-mclaren-2/none/
https://www.scalehobbyist.com/catagories/Detailing_and_Weathering/SMO00008020/product.php?gclid=EAIaIQobChMIh7-Bo9T53QIVxFuGCh1qKgOKEAQYASABEgLuS_D_BwE
I'm a bit of a newbie when it comes to photo etch.  I've done some photo etch but have never replaced surface detail like some of the dashboard parts like the AC vents and radio parts.
What would be a good way to remove the existing surface detail?
I have one of these that I have used as a chisel/scraper but am not sure that's the safest way to do it.
I also have some fine 600 grit diamond bits for rotary tools and a jewelers saw for stuff like vent openings on the side of the model that get removed and replaced with mesh.
Advice is appreciated.  Thanks
Dave
    May 2013
Posted by Greg on Tuesday, October 9, 2018 11:12 AM
I'm not coming up with great ideas for removing that particular surface detail, hopefully others will.
In the meantime, my comment is the first thing I try to do when adding PE is decide will the PE part actually look better? From your pictures, I'm not sure some careully applied paint might actually look better than the PE.
Just for your consideration.
    September 2012
Posted by GMorrison on Tuesday, October 9, 2018 11:19 AM
I do not recommend power sanding for this small scale of detail.
    July 2008
Posted by jeffpez on Tuesday, October 9, 2018 11:54 AM
I've built this kit twice and love it. I doubt that any PE parts will enhance the kit because the plasric detail is already terrific plus most of the parts will never be seen. I usually use a knife to remove surface detail for PE and then sand if necessary. If you've already completed and painted the interior then it's probably too late to be adding PE. The kit supplied dry transfers for the door sills and engine shroud are terrific but that's as far as I'd go. Please post a few pictures when you're done. It looks like you've done a great job so far.
dlh
    March 2017
Posted by dlh on Tuesday, October 9, 2018 10:39 PM
jeffpez
Well, those photos are not mine.  I've not started that kit yet.  I used photos from the internet.  I'm beginning to realize that just because I have the PE, doesn't mean I have to use it.  Thanks for the reply.
Dave
    July 2008
Posted by jeffpez on Wednesday, October 10, 2018 10:38 AM
Please don't let me discourage you're using the PE. What I'm suggesting is that you look at each peice and decide if it will ever be seen and if so will it enhance the model. I think you'll find some of it will be terrific and some won't. If you already spent the money to buy it you also now have a valuable learning tool.
dlh
    March 2017
Posted by dlh on Wednesday, October 10, 2018 11:23 AM
jeffpez
Thanks.  I try to do something new on every model, just for the learning experience.  Lots of learning presently on an Italeri Mefistofele. Used machined/PE  toggle switches on the dash. Gauge lenses are Bondic UV cured plastic
The wood floorboards and firewall are an idea copied from Harry Pristovnik's build of this model. But I used a thin basswood backing for the pieces; tiny brass nails for the screws.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, October 10, 2018 12:01 PM
Very carefully....
dlh
    March 2017
Posted by dlh on Wednesday, October 10, 2018 12:08 PM
Very carefully....
Yes, I was waiting for that one. Confused
    June 2014
Posted by Tanker - Builder on Thursday, October 11, 2018 8:35 AM
AWESOME ! !
    June 2014
Posted by Tanker - Builder on Thursday, October 11, 2018 8:40 AM
Dave ;
 useing P.E. Has to be a judgement call on your part . If you are good at dry - brushing and handling a Molotow pen then I wouldn't even suggest using it .
 There are many times on tamiya and Hasegawa models I do NOT use P.E. , using painting techniques instead .There's no modeling law that says you have to use P.E.
 P.E. is great for grilles and meshes , but a lot of the other detail does just fine with paint .
    November 2008
Posted by plasticjunkie on Tuesday, October 16, 2018 10:10 AM
There are a lot of pe parts out there but the first thing you need to evaluate is if the pe part will add more detail than the kit part. Sometimes a kit part is replaced with a pe one where no detail has been enhanced So why go thru the hassle? Other times the pe shoots up the score 100% and gives a WOW factor to an otherwise plain and sparse area.
As for removing surface detail, I like to go slow and avoid power tools if possible. It’s very easy to remove more and ruin parts this way.
 GIFMaker.org_jy_Ayj_O
