Thanks all for answering!
I forgot to mention that I did apply a coat of primer. I'm not sure how good it is, as it is a Shikiso primer (an argentine and mostly unknown brand). Also i'm not sure if I applied correctly, is the first time I used it and wanted to avoid creating a too thick layer.
Also, I do not think it is the curing time. I did not have to much time, so the model was untouched for a few days between layers.
I have been using Humbrol enamels up to now, this is my first try with airbrushing acrylics. It is pretty difficult to access to other brands where I live, so I will probably stick with Humbrol for now.
I have another question, how should the Future (or any other gloss coat) be applied?. I have seen that if I apply a light coat it does not becomes glossy at all, but I don't want to spray a layer that is too thick.
Thanks!
