AMT 1967 Impala super sport
    May 2019
Posted by Supernaut on Friday, May 10, 2019 10:11 AM
Hi I have just brought the AMT 67 Impals Super Sport kit and I want to modify it to turn it into ”Baby” from the Supernatural tv show . Has anyone got any thoughts or tips on changing the roof line , rear pillar , installing the rear doors and putting in a false bottom of the boot (trunk)
Thanks
Steve
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, May 19, 2019 11:20 AM
I don’t know what you experience level is but I can assure you it’s not for the faint at heart. The roofline does not need to be modified but the car body will be needed to be extended. That means a lot of cutting involved, adding styrene sheet, adding the rear doors, extending the interior to convert to a 4 door model. Basically a ton of modifications that can be very daunting and difficult for a beginner.
You‘ll probably need to get 2 of the same kit.
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, May 19, 2019 12:46 PM
Another option is find a 4 door 1967 Impala SS resin aftermarket kit with interior. Of coit’s, the main frame will need to be extended as well.
