Battle Damage
Battle Damage
Posted by Anonymous on Wednesday, April 7, 2004 12:39 AM
I'm venturing into new territory and my imagination may have surpassed my skills. I'm looking to set a diorama involving U.S. Marines investigating a shot-up Iraqi technical. The problem is I'm not sure how to make the "technical" look shot up. In particular I'm looking for ways to simulate holes that don't look like a drill made them, and charred metal from a fire or explosion. Any advice would be superb!
Posted by Anonymous on Wednesday, April 7, 2004 1:42 AM
Miguel Jimenez's excellent book; Euro Modelismo "Rarities", has several superb dioramas of destroyed vehicles. He details techniques such as shot holes, burnt paint, fading, rust, paint chips, smoke effects and more. It may be hard to find, but well worth looking for. ISBN:84-95464-10-1
    May 2003
Posted by qmiester on Saturday, April 10, 2004 6:36 PM
Shep Paine's book on dioramas has a section on applying battle or wreck damage to a model.
Quincy
Posted by Swanny on Saturday, April 10, 2004 7:37 PM
Sand inner surfaces until paper-thin first then blow your holes through.
Posted by Anonymous on Sunday, April 11, 2004 8:33 AM
Drill a little hole and twist a hobby knife around to make the edges uneven
    August 2003
Posted by tweety1 on Sunday, April 11, 2004 10:42 AM
For 'torn' metal, either inner explosion or outer penetration, I sand the styrene till it's thin enough to look like metal suiting that particular scale, if that makes any sense.Confused [%-)]
Then I take a soldering iron and hold it close enough so the heat from it begins to warp the styrene, then I 'tear' it with a hobby knife.
Works quite well.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
Posted by Anonymous on Monday, April 12, 2004 11:31 AM
Fortunately battle damage is wide open so a lot of different techniques and skill levels can work well. The thining out of the styrene that these guys have mentioned is the most important in my opinion. Then you can do whatever you want with the plastic, puncture in for bullets and shrapnel or pull out for explosion. I like to heat the piece against the light bulb in my work lamp, it's usually right above my head and it's slower so I have more control. The fenders here have been bent that way and the small pitting and damage to the front plate are done with a dremel by bouncing it.
There will be plenty more hurt put on this Tiger, I just included this pic to illustrate how the subtle can also work as 'damage'. Have fun with it, who's to say what metal will do under the punishment, if you go too far, then it's really, really damaged, right?
Posted by Anonymous on Tuesday, May 25, 2004 12:43 AM
Thanks all. It's coming along slowly, but I'm pleased with how it's looking so far.
