Casting resin parts in 1/72
    May 2014
Posted by Matt Sawyer on Sunday, August 4, 2019 3:58 PM
Hi, I am planning a 1/72 scale armor project and want to try casting some of the parts I plan scratch build for it so I can make duplicates of them. I have never cast in resin before, and want to get as much info on it as possible. All constructive comments welcome.
"He who dares wins."Cool
"Keep your stick on the ice."
    September 2012
Posted by GMorrison on Tuesday, August 6, 2019 11:58 PM
Micro Mark sells a good all-in-one resin casting kit, as well as individual replacement supplies.
It works well, has good instructions.
    August 2005
Posted by EdGrune on Wednesday, August 7, 2019 7:52 AM
Smooth-On  (Smooth-on.com) makes multiple products for resin molding & casting.   Check their website.  On it there is a series of video tutorials including one, How to start resin casting and live to tell about it.
Check too their distributor list for one near you.   I have one nearby and I can buy over the counter.  They are also helpful in answering my questions
They offer a starter kit which includes OOMOO-30, a 30 Shore weight RTV, and a 5 minute white resin.  Also included are some spritz bottles of mold release.   Regarding Shore weight the higher the number the stiffer the RTV.   Shore 60 is too stiff for resin but may work well for concrete.  Shore 20 is too flimsy.   30 is a good compromise IMO.
Smooth On is 1:1 volume mix so you don’t need to mess with weights or smaller volumes.
Posted by Don Stauffer on Wednesday, August 7, 2019 8:54 AM
Hobby Lobby has casting sets.  Using one of their 40% coupons might be a way to get started.
Here is my experience with RTV molds and urethane resin.  Biggest issue is design of mold. If you design mold right you do not need vacuum equipment.  Main source of air bubbles is not in the resin itself, it is air trapped in the mold.  You must leave a way for the air to leave the cavity without conflict with the incoming resin.  I find a J-shaped channel for bringing the resin into the mold, along with vent tubes rising from each local high spot in the cavity makes for a good mold.
Also, the resin itself seperates when it sits for awhile on the shelf.  So it is important to mix the resin itself well even before adding the catalyst to it.
    September 2017
Posted by Strongeagle on Thursday, August 8, 2019 7:31 PM
Ahoy Matt.  I've got the itch to try my hand at resin casting also.  I found this good, short video from none other than FSM's own Aaron Skinner.  He makes it look simple and painless and it answers some of the basic 'how to get started' questions.  When you've finished part I watch part II.
https://www.youtube.com/watch?v=vr4OlQIARc8&t=16s
https://www.youtube.com/watch?v=Md1acWONuRQ&t=16s
    May 2014
Posted by Matt Sawyer on Thursday, August 8, 2019 7:54 PM
Thanks Strongeagle. Watched both of them and I must say that it seems pretty straight forward.Smile
