Zap Glue
    February 2004
Zap Glue
Posted by glock232 on Friday, April 9, 2004 3:47 AM
I use Zap Glues and i just cut a hole in the tip and dry fit the parts then glue one side, hold the parts together and thats it.. i was reading something and they said that when gluing using cyanoacrolyte glues, you should apply it to the seam of what your gluing with a curved knife or something similar.. anyone have any tips for applying glues, im open for chance im tired of gluing my fingers together with runoff..
    May 2003
Posted by styrene on Friday, April 9, 2004 6:04 AM
I usually put a few drops on a piece of aluminum foil, or a small glass plate. Then I use an X-acto (or equivalent) handle with a piece of small music wire chucked in place. I simply dip the wire in the glue, and apply. If you want to apply a slightly larger dollop of glue, simply bend the wire tip into a small loop, or cut the eye of a sewing needle in half and chuck that in your handle. There are also ready-made applicators on the market, if you want to spend money. Check out www.micromark.com
Hope this helps
Gip Winecoff
Posted by Anonymous on Friday, April 9, 2004 2:46 PM
I put a little bit at a time on some wax paper, and then either use a sewing needle point or toothpick, depending on the application.
    May 2003
Posted by qmiester on Friday, April 9, 2004 6:46 PM
I have some of the medicenal cups, the kind that hospitals give you your pills/medicine in. Origionally got them to mix/thin paint but have found that if you turn them upside down on your bench (empty of course) there is now a recessed area on the bottom which perfect for dispensing CA. Origionally got the cups in packages of 1000 at a hospital supply store in Topeka but have lately found them in packages of 50 at Hobby Lobby and some LHS's.
Quincy
